Electrical Issue I need help!!
Michael Stiles
Charlotte
Michael
So the other day I was driving to work and as I rolled up to a stop light my truck died. I went to restart it and nothing. Completely dead with none of the gauges on the instrument panel working at all. I've done a bit of research and went through the steps in the Haynes manual to pinpoint what the problem is but I'm having no luck. Work I've done so far:
1. Checked the battery as suggested in the manual and it's good.
2. I've checked the starter and solenoid and they are good.
3. I've replaced the ignition starter switch located on the top of the steering column under the dash because some of the research on other forums indicated that it could be the problem. Still nothing.
To clarify, on the day the truck died I had just ran it through a car wash to get the grime off. I'm curious as if to this would have anything to do with the problem. When I turn the ignition switch on nothing happens on the instrument panel, however, headlights and horn still work. I'm not great at this electrical troubleshooting and could use some advice if there is any to be offered.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Could of popped the fusible link at the starter. Do you have 12v at the junction block on the firewall?
Michael Stiles
Charlotte
Michael
I don't know I haven't checked. I talked to a guy and he mentioned the fusible link and I was going to check it that today. That'll be the next thing I do and I'll let you know.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
:waytogo:
B.K. Cunningham
Spokane, Washington
Bryan
25 Hundred
you say its a manual? check the plunger attached to the clutch under the dash. mine broke while I was at napa a few weeks ago. I got lucky. 13 bucks for a new one.
Michael Stiles
Charlotte
Michael
Okay thank you. I'll post what I figure out when I get home and get under the hood.
CSFJ
Iirc, the nuetral safety switch won't take out the gauges and dash lighting.
I was thinking fusible link as mentioned.
M37M35
