SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- Rob
- C20
Thanks, it's not streamlined or built in, but for me I don't need that. Installation was simple as will any future service if need. It is bulky, but it's kind of about the only switch of this type. I had two choice this Pollak switch or a Standard switch. Both made by standard, but the standard did not include the mounting strap.I like the sturdy, purposeful look of that switch and because the wiring is neater I like it on the side of the shifter closest to the dash. It does seem to be a bit bulky for your application though.
I know that if I were walking past a truck like yours I would look inside it. I would notice that switch and would not have a clue what it did. I would tell myself, "I don't know what that is but this guy is USING this truck and that has something to do with towing things!" I actually like that look.
I once drove an older Ford 4wd diesel on a farm that used that exact switch for the 2 speed rear end. I was about 21 years old at the time and thought that was the most Truck Like thing ever.
Ya, I have to say I agree with your thoughts. I have two concerns about it being on the dash side of the shifter.I think the switch would be better in front of the shift knob. The wiring isn't as sleek that way, but grabbing that knob to shift requires a little pull forward so you're always handling the back of the knob. Having the switch on the back means it's always getting grabbed to shift, right???
Even if the wiring is not as "safe" cause it's off the shift rod, I think it's relatively safe in that area.
#1. Have to wrap my hands around the switch the move the shift lever.
#2. Have to remove, or nearly remove hand from steering wheel to operate it.
Pros:
#1. Wiring more out of sight.
Concerns about it being in front.
#1. Because of wiring exit on the switch and the shape of the shifter lever, the wiring sticks out more from the shift lever. I think it's unlikely it would get caught on the keys / ignition switch so mostly cosmetic.
Pros:
#1. Can operate switch with hand on the steering wheel, by using fingers.
#2. Does not interfere with putting hand on shifter to move lever.
It doesn't look like I'll have the truck out until Monday, but when I do we will see how I feel about the switch location where it is now (backside of the shifter / dash side), and I'll run it like I would if I was loaded so I can get a feel for how I like operating it. Function will be more important that looks in the end.
Thanks for the opinions and thoughts guys, I'll update you after I've driven the truck a bit.
