Electric Speedo
mags468
Bradford,Pa
Nick
Suburban
I have a 1990 Suburban R1500, can the electric speedometer be switched to mech.?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Pretty sure that's possible, but you'll need a tailshaft housing and the correct drive/driven gears from a 89 and down.
Only thing I'm not so sure of, the ECM needs that signal in order to achieve lockup on the transmission and for cruise control to function.
But to the best of my knowledge, it's obtained 1 of 2 ways, (cable or wired)
Wired (like yours) :
on my 90 I had, it had the vss at the trans, which next went into the back of the speedometer, then you have the DRAC module (approx under your radio, behind the dash). Which defines tire size and gear ratio to properly calibrates the speedometer's electric signal (pulses) going to the ECM.
Cable:
Like my 89 or 87, you just have the cable of the tail housing leading into the speedo, and the vss behind the speedometer has an optical sensor of some sort that reads off of the speedometers rotations to communicate (via pulses again) with the ECM for lockup.
Vbb199
Salisbury NC
Vince
Someone may have better input on this subject, with a more descriptive explanation, but that's to the best of my knowledge how the 2 setups function.
mags468
Bradford,Pa
Nick
Suburban
Thanks for your help.
Vbb199
Salisbury NC
Vince
What's your motives for switching over? Is your speedo getting stuck at 63 mph like they all seem to like to do?
squareframe
