Edelbrock intake for vortec heads
77 K20
Montana
K20 5" lift
HT383 fuel injected
First of all- this intake (and a second one I bought) I had issues with using the external plumbed heat plenum under the carb. The casting was porous somehow and would leak coolant up into the air intake after it cooled off.
To prove this I ended up bypassing the heat plenum and it wouldn't use a drop of coolant. To run without it the NPT elbows I installed should be removed and plugged off with NPT plugs. (Which I have, I think). The heat plenum is optional to use. It is in the original box right now, and it has a 180* thermostat and thermostat housing already on it.
This manifold would be great in my opinion for someone that lives in a warm climate or who won't use the vehicle in winter.
I didn't want to sell it locally as it is a cold climate here.
Summit Racing has the Edelbrock 7116 for $242 and there is a $25 rebate on it right now. ($217).
I was just going to throw it out... I'm tired of tripping over stuff in my garage. I figured there would be forum members here that could benefit from it. I'll even send it out to you so you can install and verify it works good before payment. As far as that- just make a reasonable offer.
https://www.summitracing.com/parts/edl-7116
picture.php
atb450
Southern utah
Adam
Still available?
Is this manifold still available?
77 K20
Montana
K20 5" lift
HT383 fuel injected
Yep, I still have it. And it even has the Edelbrock intake manifold gaskets that they recommend (new in the package). I didn't use them and went with Fel-Pro instead.
atb450
Southern utah
Adam
I can get a Tbi adapter to bolt my Tbi on that intake correct?
atb450
Southern utah
Adam
How much do you want for it?
77 K20
Montana
K20 5" lift
HT383 fuel injected
I've seen a few TBI to square bore adapters online although I haven't used them. Trans-dapt and Holley make them that I know of.
For price I was just thinking $25+ whatever shipping will be.
74 Shortbed
A little late, but if these guys don't take it I will..
atb450
Southern utah
Adam
I'll take it how would you like me to send you the money. Is there a way to private message here
atb450
Southern utah
Adam
77k20 I think I p'med you. Let me know if you didn't receive it thanks.
atb450
Southern utah
Adam
Also thank you 74 short bed for the info.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Sold.
aaron06
