dual tanks only one works
zoomiah
delray beach
jeremiah
GMC
I have a 79 gmc sierra grande stepside that was originally a diesel converted to 350 gas with dual tank setup. Only one tank works all the time, when i switch to the other tank at highway speeds it lags and feels like it doesnt seem to be getting enough fuel, anyone know why or how to fix this? thanks
Stroked
Beloit, Kansas
Jared
Hmm...that's a tough one to diagnose. Could be the pickup is full of crud in that tank or a plugged line.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
good call. the selector valve could be gummed too.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
With mine the old fuel lines were breaking down and plugged the valve up.
zoomiah
delray beach
jeremiah
GMC
Thanks for the responses guys! is there anything i can do to try to figure out what it could be for sure? any help is greatly appreciated!
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
Are you holding the switch valve on long enough for it to fully switch? Could also be a pin hole in fuel line on second tank drawing air.
Jims86
Patterson,Ca
5.7 TBI
Best advice is to go ahead and replace all the rubber lines. may fix it, andnwill give you piece of mind.
zoomiah
delray beach
jeremiah
GMC
I will work on replacing the lines and see if that fixes it. they need new ones anyhow! thanks guys
td87
CT
Trevor
V20
2 different fuel pumps? Because I had a similar issue with my aux tank, replaced the pump and it fixed the issue
aaron06
