Dual tank rust question
RustyBuckets
Kansas City
Jake
Im back to ask ya'll for help. I had a gas leak that i figured out was a fuel line when i pulled the tank. After i pulled the tank i realized i had pretty bad rust under the straps. Im lookin at buying a new tank and probably 2 once i check the other and its rusted to.
My questions are both tanks on dual tank models the same(part numbers) and what should i use between the new tank straps and the new tank as a pad. Also if i buy a new tank is the exterior coated or should i paint it.(buyin from rockauto)
Thanks for any replies
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Well, they're the same tank for the right and left side, but the short bed tank is 16 gallons and the long bed tank is 20 gallons. A 16 gallon tank will work on a long bed, but not vice versa. I know some people put the smaller ones, but I'd want the extra capacity. I would use something thin and fibrous as close to the original stuff as you can readily find. Maybe something like this and trim it to fit.
http://www.homedepot.com/p/UltraTou...clsrc=aw.ds&dclid=CIXtkNCex9YCFQE4TwodONEG2w#
As far as the new RockAuto tank goes, I installed one a few months ago, it came coated and ready to go.
Camar068
10 yrs Air Force
I used the silver bubble wrap insulation on mine. I had some laying around. Seen mention of roofing paper as well.
RustyBuckets
Kansas City
Jake
Thanks ill give that homedepot stuff a shot.
JD1973
AZ
Jonathan
Chevy 1/2 stepside
if the home depot stuff doesnt work, go to LMCtruck.com. they have everything yo will need
Azathoth
W TN
Ed
Back when dinosaurs roamed the earth and there was only one VanHalen, most people cut up old inner tubes for this.
Wish you were closer, I'm swapping my 16 gal for fuel injection tanks.
scwaters
Chester Springs, PA
Sunny
K10 Shortbed 4x4
I have a 1976 short bed that has a switch in the cab for dual tanks but only one tank on the driver side. Can anyone tell me if I want to install the tank on the passenger side is it the 16 or the can I fit the 20. The passenger side of the truck does not have a filler door. Which is easier replacing the entire bedside or cutting the door out A junker and welding it in to the existing passenger side?
RustyBuckets
Kansas City
Jake
I wanted to follow this post up and thank you guys for your help. New tanks are in :). I ended up finding this rubber trim for the tank pads in the flooring dept. I ended up having to fix some of my my tank strap brackets as they were too rusty to salvage the spot where the strap bolts on. I will link photos of how i did that in case someone needs to do the same.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Glad everything worked out!
mikejeden
