Daveo91Burb
- Jul 6, 2014
- Vancouver, WA
- Dave
- V2500 Silverado Suburban
- Vortec 383, modified TBI/4L80e
So my '91 Burb does not have dual batteries but the '90 parts burb I had for awhile did. Both are 350 TBI. I took everything along those lines from the '90 before I got rid of it including all wiring, the tray, even the batt itself. Is it as simple as installing the tray on the drivers side and then wiring the positive to the terminal block on the firewall and then grounding the negative? I will want to use an isolater so the two batts don't have to be exactly equal and one will not drain the other. Where does that go? Any other suggestions?
