Drop Shackles on a Suburban???
85Squared
Maryland
Kris
Suburban
Hey guys,
I had plans on using drop Shackles on my Burban since I had done them before on my R10 but I discovered today as I was looking under the truck and saw the tub for the spare is smack-dab in the way of the bolts on the stock shackles so I can't see any way to pull out the bolts on the driver side. I really didn't want to do an axel flip cause I wasn't looking to go that low but I'm not seeing an alternative, any advice??? Thanks
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
interested in this as well... My 88 Burb has had leafs removed to lower and the axle tube is almost touching the bump stops. so needless to say, not much room between tube and frame.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I have a flip kit and drop,shackle up for grabs. I just finished bagging my square......just saying.
radio2000
South Carolina
83 and 88
What all is included?
Congrats in finishing the bag
smoothandlow84
Steve
In the flip kit?
All hardware including the u bolts, the flip kit saddles, the base plates.
smoothandlow84
Steve
Thanks, it was a pita removing the hanger rivets that GM used to attach them to the frame. Welding underneath any vehicle is not fun, especially when molten slag falls and burns through clothing
gpmorgan
Tupelo Ms.
greg
I hope you had the bed off.
radio2000
South Carolina
83 and 88
I've had the "pleasure" of removing those rivets... No easy way
smoothandlow84
Steve
post: 360674, member: 4692"]I hope you had the bed off.[/QUOTE]
Nope....I did everything with the bed on. I had to plan ahead and double check all of the measurements. Luckily I have a lift.
smoothandlow84
Steve
I found that using a sawzall to flush cut the heads of the rivets first worked best. I used a air chisel with a pointed round tip to punch them throught the backside of the frame. Noisy, but quite effective.
radio2000
South Carolina
83 and 88
Interesting, we've always ground the heads down then used the air chisel.
Cotas86
Phoenix
Anthony
In the flip kit?
Are those u bolts and leaf plate specific for that kit? Just got my flip kit and was looking to get new u bolts and plate.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I just cross cut the head knock them pieces of with an air chisel and pop them out with a drift in my air hammer pointed ones work but will widen the shaft and make it harder to get them out and turns them into projectiles.
smoothandlow84
Steve
I am not 100 percent sure. I would think that as long as the leaf packs are the same width, it shouldn't matter. If both are 1/2 tons vehicles, probably the same.
jingle1
