Driver side brake assembly not working
PauL3465
New York
Kevin
K20 Custom Deluxe
6L?
Driver side brake light, reverse light, and rear turning signal do not work. I'm new to square bodys and trying to get this to work before winter for plowing. I'm not 100% sure where yo check first or if there's just a fuse I need to check for the whole assembly.
WP29P4A
Nevada
Sierra Classic V1500
It's most likely going to be a bad ground, on several models the ground is attached behind the tail light housing, or near the license plate mount. Find the wire that is screwed to metal. Make sure its clean and tight, no paint, no rust. If it was a fuse it would affect both sides.
Don't miss the obvious... have you checked the bulbs?
Pugs Speed Shop
