Double up on th400 pickup tube o-ring
Double o-ring or single on pickup tube
  • double
    Votes: 0 0.0%
  • Single(oem)
    Votes: 0 0.0%
  • Total voters
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
should I? Pan in question is a new deep Hughes performance. Came with pickup tube but no o-ring...
I’ve read where some say to use two. Seems odd. That would give the case less surface area for friction on tube and force the filter further down than designed.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
$200 trans pan and not a scratch of literature, awesome. Bolt lengths are different. Shorter bolt in a deeper pan...makes sense, lol!
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Apparently the filter isn’t suppose to float around with the new setup. It bottoms against the supplied aluminum spacer.
Glad I used only one oring. The filter fit exactly on the raised pedestals without much extra room.
This definitely made my trash look more sexy
yevgenievich
Viktor
sad
very sad
less sad
The two o rings would have been for deep pan that does not have raised support. My deep pan came with pickup extension
I installed a B&M pan several years ago, I don't remember instructions with it either.
sammygunns
