Door hinge won't come off
Gm84HighSierra
Missouri
Austin
84 GMC
I have an 1984 gmc k1500 and I need to take the door hinges off to sand and paint it but there is a bolt going through the back that I cant get to to it take off. I have to have it off and I need to know how. Do you possibly know how get it off?
Ooh ooh - pick me, pick me. I know this one;
Get up under the dash look on the outside wall and you will find the access hole for the bolt head (9/16"?) It's way up - about even with the rubber grommet where the wires to the door jamb switch pass through the wall but further back. It's about in line the handle for the fresh air vent when closed (if you have one).
It is really deep, you can barely touch it with your finger tip. Use a socket, a 6" extension and a 3/8 drive ratchet (and work from under the dash) to back it out.
MadOgre
NA
NA
NA
NA
NA
I think you have to pull that rubber grommet with the single white wire to access the bolt for the lower hinge ? I think lol
Gm84HighSierra
Missouri
Austin
84 GMC
This is the upper hinge I am trying to remove
MadOgre
NA
NA
NA
NA
NA
Ya its the rubber grommet with the white wire to get at that one. I couldn't remember which one the grommet accessed but after looking at your pic it is for the upper one.
Pull the grommet out and then you will see the bolt through that hole. Its there
You have to remove the glove box to be able to see the grommet and be able to access the bolt with a socket
Kipps5000
