Door has a loud metallic pop when closed
rnason
SoCal
Ryan
This just started recently. When I open the passenger side door all the way and start to close it, there is a loud metallic pop. It does not happen on the drivers side. Is there anything that I could check into to stop the issue? It is a 73 K20.
rnason
SoCal
Ryan
It shouldn’t be. The truck is really straight with no frame or body damage. Hasn’t moved more than a few hundred feet for over 5 years, and it just started recently.
TX87R10
Patrick
R10
Does it sound like a spring or like metal contacting? My driver side door while driving down the road makes this load metal spring popping sound that scares everyone but me, and I think it is a spring in the door that needs grease or something
rnason
SoCal
Ryan
Could be a spring like you were saying. I was thinking it could be something binding in the system that holds the door open.
Jwernatl
Senoia, GA
5.7ltr
it could be this... Mine is broken. its the detent..it holds the door 0 there are wheels that roll over it. - It's a spring. is it binding??
rnason
SoCal
Ryan
I will check when I get to go work on the truck next. Thanks for all of the help.
garrettkeith
