do i need to drop tank to get to ground?
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
was looking yesterday at the drivers side tank. but can't find where the grounds are for the tank. is it accessible w/o dropping the tank? if i need to drop tank, i think the cat converter heat shield is in the way.
lots of threads on bad grounds, no so much on their actual location
The ones I've messed with, the wire went directly to the top of the frame rail. The eyelet is fastened down by a bolt with a 1/2 inch head. A ratchet wrench is handy here.
87silveradok20
Ohio
Levi
Silverado k20
you could pull the bed, but im sure thats not the answer you wanted. :)
flyboy1100
UsA
me
k1500
pulling the bed was my other idea. or at least removing the bolts and raising the front of it. might end up being a project for next summer.
i did see the wire where it went to the sender, but it was a "y" or some sort of rubber boot connection and i couldn't see where the other end went.
MrMarty51
Eastern Montana
Martin
Probably have to clean off some dirt/mud but, it should be inside the frame rail, within a foot or so of the sender unit, a foot or so frontwards or rear wards inside the frame rail.
flyboy1100
UsA
me
k1500
I will get a mirror down there and look.
How many bolts hold the plastic shield on? I am going to remove that so i can see if the tank leaks once i put some fuel in it
Sent from my SCH-I605 using Tapatalk
MrMarty51
Eastern Montana
Martin
Tank on outside of frame rail, ground on inside, do`nt need a mirror, just get under there and LOOOOK.
As many bolts as there are on it. ? ? ?
flyboy1100
UsA
me
k1500
Huh, i didnt see any grounds on the inside, will look harder tomorrow if i get a chance
Sent from my Nexus 7 using Tapatalk
K5Chris
