dash questions.
4thgentruck
South Carolina
c10 shortbed stepside.
Is it possible to runn a 95 or so dash without running a computer. If not do I have to run the computer hooked up to the motor.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Yes, and no. only the DRAC MODULE.
4thgentruck
South Carolina
Where would I pick up a DRAC module, and where would I need to locate it.
marks86
Latham, NY
Mark
12v Cummins
I dont understand you want to run a GMT400 dash in your square?
4thgentruck
South Carolina
Well I'm wanting all the comfort, plus all my interior in my square is broke and in bad shape. I can get a 95 dash for 50 bucks at the salvage yard.
80goldenburb
LV,LV Raider Nation capital
Nico
Suburban C20
'68 cad 472
Yes you can run a 95-97 cluster with a carbed engine. i am running one now. The DRAC module is for speedo calibration and can be found under the dash near glove box (passenger side). Use the calculator to at tbi chips to determine what jumper calibration is needed. At first, you might have to go up a few chart ratios to get it correct speed like i did. (i.e. input ratio for 33s and 3.21 gear - 0.605644, closest chart input ratio listed - 0.604492, CORRECTED speed calculation I am currently using - 0.632324) Right now i have the wire from the speedo connected to the output (rear) speed sensor on my 4L80.
ThisOldK10
Nevada
R1500 Suburban
5.7L 350
How does you are overall dash look? Did you retrofit that cluster into the original dash or are you using a different dash? curious to see.
80goldenburb
Nico
Suburban C20
'68 cad 472
as of now it is retrofitted in the original dash. Retrofitted as in zip tied to the screw holes LOL.
87R10_Cruising
