Dana 44 vs Corp 10 bolt front axle
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
And that’s all we have for today’s show of 4x4101 with @shiftpro
Tune in next week for more tips and tricks to get your rig muddin!
Seriously good info tho
Just I just get relieved of my duty here?
77 K20
Montana
K20 5" lift
HT383 fuel injected
Yes your right. I just passed over clutched or the limited slip type. They are kinda Beta male compared to a locker but much better than nada. But they eventually wear out! And lockers don't wear out but... one mistake and there goes a knuckle!
The truetrac are geared- so I've never heard of them wearing out. In fact once the gears wear a "pocket" into the sides they work a bit better. And you just use normal gear oil. No friction additive.
In my previous truck I had the original design lockright in the 12 bolt rear end. Broke it. Then switched to an Auburn gear pro limited slip with the cone shaped clutch plates. Worked ok for the street and gravel roads. Not much for offroad. Wore that one out. Sold the truck.
Bennyt
Surprise
Ben
A tru-trac up front works great for everything other than a dedicated trail rig. I ran a Detroit locker in the ff14b and a tru-trac in the d44 front of my K5 for many years. 35" tires, 4.10 gearing, 700r4, stock TBI 350 w/ vortech supercharger(5psi). Good gas mileage, plenty of power, went anywhere.
I have put tru-tracs in the rear of a few cars, my '63 Nova has one currently as well. They work great, don't push/pull in turns, plenty of traction.
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
They don't break until you really are far from home with hungry kids and wife on the rag and you have to pee.
I have broke axles, and stuff. But I know it's my weakest link for now. I do carry a couple parts for it with me.
The last time I had it weighed was at the recycling plant after dropping off metal. We all know they cheat us a bit. But it was just a tad over 6,000.
RoryH19
Rory
R10 Silverado SWB
Thanks everyone for the good info.
dvdswan
Port Orchard, WA
Dave
Yeah you don't let your girlfriend drive your truck with axles locked...
Actually even if the truck is on jackstands with both axles out... don't let your girlfriend sit in the drivers seat.
Sorry Goldie...
Sounds like a fire side story is in the midst.
Gather 'round children, grab your smores and popcorn, Uncle shiftpro is going to tell us a great story...
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Thanks I assumed the Truetrac had clutch plates, like the old GM Posi unit.
My first fully (front and rear) locked truck had LockRight lockers. They were cheap but got the job done. I have no problem imagining them break however... This was my firewood truck I built back in my logging days (and it was a ford, shhh!)
77 K20
Montana
K20 5" lift
HT383 fuel injected
It is a pretty ingenious design- wish they had more about the theory of it.
RoryH19
Rory
R10 Silverado SWB
Can anyone confirm that the late 80's - 91 Suburban/Blazers have 30 spline axles in their corp 10 bolt?
Dana 44: 30 spline axles
Corp 10 bolt: late 70's - late 80's 28 spline axles
Corp 10 bolt: Late 80's - 91 Sub/Blazers 30 spline axles
3dbello
