Curt 13028 class III hitch install
John Reason
Bath, NC
Any of you guys installed a Curt 13028 hitch on a square body. Trying to install on a 83 K10 and don't see where I can use on of the previous holes to get it started. Looking for some pointers . Its supposed to fiy this truck
I think that's what used to be on my short bed. I don't remember any extra holes drilled in the frame, but I'll look into it.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
It looks like the holes would line up? It’s just supposed to sit flush on the bottom of the frame rail
Craig 85
Nashville, TN
454/TH-400/NP205
CarParts.com
Carson, CA
CarPartsCom
N/A
Eric from CarParts here- Yes, you need to drill holes and there should be 6 spacers that go between the frame and the hitch. Looks like you also remove the last/rear most bolt for the spare tire holder. Once it's lined up I use a couple pairs of vice grips to hold in place and drill away. Start with one hole on each side then install bolts and finish off the rest.
John Reason
Bath, NC
Thanks for the help guys. Just wish they could deisgn one where no drilling is required. Must be quite a few frame variations on these trucks.
whagge
