cs 130 alt upgrade
350runner
tx
Ceasar
Theory is to have the system drain the alternator charge more than the batt. I'd still wire it straight to the bat if it was me. This was mainly to show the difference in alternator output when changing the sensing wire location. I'm gonna try changing the location of the sensing wire from the back off the alternator to the firewall distribution block and see what affect it has.
MadOgre
NA
NA
NA
NA
NA
Let us know how it works.
350runner
tx
Ceasar
You bet! I have way more draw with the kicker zx750 than most do with their factory setup. Anyone who is looking to do this upgrade should also look into a smaller pulley as well it's necessary if your having charging problems at I idle... check the link in post #10 it shows when these alternators start charging.
I put a cs130 on my truck today. I got the plug from orilys for $20. Had to alt already so im in it prety cheap my lights seem brighter seems to run better and when the fans kick on it doesnt drag the motor down as mutch. Everything seems to just wrk better. It was prety easy bolted right up pluged right in. Thanks for looking
This is sort of unrelated, but you really should ditch that fuel filter. Those things can (and often do) start leaking past the crappy seals without warning. They really are a safety hazard.
With out a resistor the alternator will be short lived
That's what everybody always says, but the first two I did are still working fine. It's been nearly a decade too. I later found out about the resistor thing, so I do it just to be safe now.
350runner
tx
Ceasar
If you check out the link I posted you'll find there are two types of regulators one that doesn't need a resistor in the wire and one that does. It's just insurance. I'd like to be safe
Edit: word change. I read other forums where people say they didn't use one either. I'd just hate to be stranded because of a 5¢ part tho. Did you do any other wiring upgrades?
350runner
tx
Ceasar
Page one
Edit... trying to figure a way to upload a pdf , but Idk how to. Anyone?
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
I did the big three... and put new grounds on motor...chassis...cab...replaced all battery cables to isolater..
starter... alternator. The fuel filter is crap its a second filter after the electric pump dont need it but used it as a splice didnt have long enough hose lol story of my life..plan on doing all an fitting dash 6-8 ?
braided lines from tank (50 gal in the bed of my truck) to pump to carb. I lnow your supposed to use hard lines as much as you can. But I dont want to....
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I assume my alt. is a cs130 its from a 92 truck
it had only 1 wire coming out of the plug a brown one
I hooked it to the brown wire from my original alt. plug and ran a wire from the lug on the back to the starter.
not sure if it works or not yet I have not started the truck yet.
I guess I should research it more 1 brown wire out of the alt to the original alt. plug brown wire seemed easy enough to me. but now I don't think its that easy.
do I need he red sensing wire?
thinking about just getting the resistance adapter plug and running the sensing wire to my power distribution block on the firewall
Pugs Speed Shop
