Crush sleeve eliminator?
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
I'm almost done cleaning up my 10 bolt and getting ready to start putting it back together. I recently stumbled upon the crush sleeve eliminator kits and they sound to me like they take a lot of the hassle out of the setup (along with being better with the shock that can come from a manual tranny).
I guess my question is, what's the downside? Is there something that I'm not seeing that makes the crush sleeve better (aside from cost)?
scottybaccus
Central Texas
Scotty
GMC R1500
They take more effort to set up, because you have to assemble and torque the nut with the spacer and shims, check rotating torque and then break it down if any adjustment is required, change the shims and try again.
With a crush sleeve, you tighten the nut, check rotating torque, tighten some more, etc.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
To me that sounds like a better system. You can go past and back up if you need to without scrapping a part. And I don't have to deal with the ridiculous torque numbers that the crush sleeves require.
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
I bought one for mine, i plan to measure old crush sleeve, add ,.002 because i read that somewhere, And test it. Fine tune from there.
Have you started the rest of your rear end yet? Mine is torn down and nearly cleaned, but there are a lot of small metal pieces in about the 1/16"range that are a pita to get out. After i get it clean time to start the backlash etc. Hoping to get most of it done saturday
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
All I've got left to do is clean out the axle tubes real good. Seals went bad and let in some mud. I'm hoping to get started on my rebuild Sunday. I've got everything except for the eliminator kit right now. Might just have to go with the crush for now and swap it out later.
scottybaccus
Central Texas
Scotty
GMC R1500
If you are replacing a crush sleeve from a good install, with the spacer and shims, you can measure the crush sleeve you take out to determine the correct shim stack.
flyboy1100
UsA
me
k1500
I don't think mine was a good install. Could have been factory too. No idea the bearings were unbranded
flyboy1100
UsA
me
k1500
Pita, but got it in. Ended with .031 worth of shims and am at 20in/lb preload, so a touch too much, but with the combo of shims i received .029-.030 wasn't possible. .028 was way too tight like 30in/lb
Sent from my Nexus 7 using Tapatalk
scottybaccus
Central Texas
Scotty
GMC R1500
If the gears are already broken in, that's expected. It should be fine.
scottybaccus
Central Texas
Scotty
GMC R1500
In a new install, I would be less concerned out preload torque measured, and take steps to ensure the pinion bearing stack is fully compressed. That can be done by over-tightening the nut, while turning the pinion. It should fully seat the races in the case and bearings on the stem. Back off the nut, then set preload. If that comes up a little light, it's not such a worry, especially if the gears are wet.
What you don't want is to have a light preload, with bearings and races to seat further with a little use, resulting in a loose pinion bearing.
If you're confident the stack was fully compressed, no worries. Just come back and check it after a few miles.
flyboy1100
UsA
me
k1500
pretty sure it was, but that is good advice. will check it in a few miles :)
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Thanks for the info Scotty.
I've decided to wait until my kit gets here to do my setup. Should be here tomorrow. @flyboy1100, I assume the final torque number for the pinion nut is called out in the service manual? I haven't seen it anywhere yet, but I don't have my manual on hand right now to look.
flyboy1100
UsA
me
k1500
Normally i torque everything, but in the case of the pinion nut i just red loctite'd it and used the impact. Another reason for me to check it in a few miles.
I do think the torque spec is in the factory manual, i just can't remember it
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
The engineer in my won't let me say "good enough" when it comes to torque numbers. Guess I'll have to go hunt down that number.
Villano
