Cruise Control Transducer Source
Im still looking for one.
If you can find out of BOP engines used same setup, I can guarantee I have the unit for you. Otherwise.. we just got snow. let me post a photo taken long ago to see if this is the part.
Once snow clears I can check to see if a 75 pontiac or a 79 and 80 olds have the same stalk and units on the engine. Small blocks.
78C10BigTen
pennsylvannia
C10 BIG TEN
Hard to tell from the pic. The vaccum part laying on the master cyl is the same
which one is the transducer. it takes the speedo cable from the transfer case and goes to the speedo cable for the dash.. yes?
78C10BigTen
pennsylvannia
C10 BIG TEN
Correct. The one hanging in the first pic
Is there any connectors or brackets that are needed or any special ways to remove? I guess I would want to make sure its good. Any way to test it?
78C10BigTen
pennsylvannia
C10 BIG TEN
Very unsure on how to test.... it appears to already be unhooked and just hanging by the vac lines.
so...
Big Chip
Michigan
Kevin
C35
so...
That's the servo and it attaches to the rear of the intake manifold with a rod to the carb linkage. Can you hold the transducer up and take a better picture?
Which one. I have two arrows pointed. And uh... not tonight because its basically blizzarding atm but when it clears yeah. maybe mention me in this post tuesday morning?
78C10BigTen
pennsylvannia
C10 BIG TEN
First pic here, circled in green. Sorry i realize i previously said the second pic in my other post. Sorry for the confusion
TubeTruck
East TN
Denis
Suburban K10
LQ9
No idea if it works bit I have everything
Big Chip
Michigan
Kevin
C35
I think the USPS lost my transducer somewhere between Minneapolis and here. Did you go with aftermarket or just eliminate cruise control?
TubeTruck
East TN
Denis
Suburban K10
LQ9
This is from my '75, which recently became a parts truck instead of a wheeler project. I got the cruise module out of a '98 Suburban that I'm going to try and make work with the factory cruise/turn signal switch in my '78 Suburban so this is just kind of laying around.
this is mine.
If you're looking for a complete set don't forget the brake switch (and clutch switch if you have a manual) and the bracket to which the switch is mounted.
The 2 speedo cables are nice to have as well.
Almost forgot, the little attachment thingy on the throttle lever too!
AND, that adjustable rod from the vacuum actuator to the throttle.
ruggedly
