Crazy speedometer
73c20jim
Tombstone, AZ
How can a mechanical speedometer be 10 MPH slow and the next day be almost dead on. GPS check.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I’m guessing either the gears inside the speedo are dry (grease dried out?) more friction, spins slower, or maybe temperature related? Cold speedo lube, more friction?
73c20jim
Tombstone, AZ
Good places to check. Thanks.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Or a crummy aftermarket cable. My speedos perform fairly well using a somewhat worn out, abused, 33 year old cable on the bench, but they do the same thing as yours in my car. I have yet to find a cable that even comes close to the OEM design. I’m on the verge of saying screw it and just putting the dinosaur cable back in.
Westislander
Massachusetts
Gregg
[QUOTE="Matt69olds, post: 457076, member: 15079] ...
Cold speedo lube, more friction?[/QUOTE]
....lube makes everything quicker
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Oh great, is this going to make it to the square body quote thread?
73c20jim
Tombstone, AZ
using OEM cable, at least it looks like oem cable.
ali_c20
Austria
Alexander
C20, K5
My speedo does the same and the faster I go the more accurate is my speedo. I have tried 3 different brand speedo cables and all of them sucked. If I ever find a good speedo cable that works as expected I'll post it.
Byco
El Paso, TX
Tony
k10 Silverado
350tbi
What about LMC speedo cable? works well?
Pugs Speed Shop
