YubaDirt
- Aug 20, 2014
- Marysville, CA
- Grey
- K10
Vehicle:
1974 Chevy K10 350/350 with AC
Questions:
1)Is the junction block and/or alternator supposed to have constant power while the key is off and out of the ignition? If not, what did I do wrong and how do I correct this problem?
2)What is the most professional source/method to draw power for the HEI?
3)Confirm the temp sending unit is a green wire? Is it a problem being a naked wire (no additional heat insulation) when used with headers?
Background:
I am completing the installation of a new engine; to which, the only external modifications are an Edelbrock Performer intake manifold, an Edelbrock #1406 Carb, headers and an MSD Pro Billet HEI distributer (the vehicle was originally equipped with points ignition).
I replaced the factory engine wiring harness because it was very rough. I ordered the harness from Brother's Truck. The harness was made by American Autowire. It came with a receipt only; no diagram or instructions. Brother's Truck refused help, claiming they were not techs. American Autowire refused to send any instructions or diagram because of liability and could not further assist without viewing the vehicle.
Between comparison to the factory harness and information from this website, I was able to complete an installation I am semi-confident with. However, using a test light, I discovered that the white wire to the alternator plug and all wires at the junction box are constantly hot.
What I did:
A) Both wire connections that exit the loom near the junction block were connected there.
B) The yellow colored coil wire that exits near the distributor was taped back against the loom to allow for later use since I will not use it with the HEI.
C) The red wire with the rubber hood was connected to the back of the alternator.
D) The white and brown wires were plugged in the side of the alternator.
E) Two fusible link wires and the positive battery cable were connected to the positive post on the starter solenoid.
F) The Purple wire was connected to the start post at the 3 o'clock position of the solenoid.
G) The yellow wire at the starter was also taped back against the loom to allow for later use since it will not be used in the absence of points ignition.
H) I connected the green wire to the temp sensor in the passenger side cylinder head.
I) I have left a wire unconnected that I assumed was intended for the idle stop solenoid. This wire also looks to be heat insulated.
Thanks for the help I've gleaned from the website so far and in advance for your advice here.
Questions:
Background:
What I did:
