Confused about pitman arm
Tyler Rea
St. Helens
Tyler
GMC K/2500
I have a 76 short wide on 33s. Thing handles terribly. Months ago my pitman arm started to clunk and move when I would turn the wheel. I have a 4 inch lift and I do have a drop steering arm so I thought that taking the stock pit arm off of my parts truck would be okay and it was for a while but started to clunk again. A buddy of mine owns a shop in town and I showed him and he said I need a drop pitman arm but everything I've read online tells me you only need to get one of the drop steering components to make it work. Do I need a drop pit arm too or could the Steering arm be too short? When I bought the truck it had the lift and the steering arm on it already so I'm not sure what the drop on the steering arm is
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
At 4” a raised steering arm on the knuckle should be plenty. Is your frame cracked at the steering box?
hirschdalechevy
norcal
rich
k-30
With a 4 inch lift you only need a raised steering arm. look at your drag link , you want it to be as flat as possible , if it is flat thats as good as it gets and check everything else as well.
On a stock height truck the drag link between the pitman arm and the steering arm is nearly level horizontally.
When you install a spring lift kit it will raise the pitman arm and lower the steering arm, so the drag link gets more of an angle. You can then buy a dropped pitman arm, and/or raised steering arm to get it back in alignment. http://offroaddesign.com/catalog/steeringcorrection.htm
Craig 85
Nashville, TN
454/TH-400/NP205
If you need new conical washers for the steering arm, it's GM 3965138. You'll need 3. Nuts are not included.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
"Handles terribly" compared to what? Is the steering sloppy?
How is the gas mileage?
Good point. A lot of people hop into these old trucks and are shocked when they don’t handle like a Jetta. Not saying that’s you, OP, but it happens.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
FWD is a very different feel than RWD.
I would of used a better example the a German designed, Mexican built turd. I think I know what was in his mind when he posted that. A MK5.....yuck lol I’d of used an A4 Quattro Sport, black trim not silver as my example lol
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yuck I can agree with 100%. You’re right, though. It’s the first thing that came to mind because I had one. I probably could have used a better example, you’re right. A Chevy Celebrity would have been a higher quality, more luxurious example.
:happy175:
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
:happy175:
I’m just bustin your chops.
Tyler Rea
St. Helens
Tyler
GMC K/2500
The frame isn't cracked at the steering box and the drag link i believe is pretty close to level if I remember correctly. I'll add a picture of the drag link after I post this.
Tyler Rea
St. Helens
Tyler
GMC K/2500
It handles terribly compared to anything I've ever driven. I've driven a few of these trucks and it's by far the sloppiest one I've driven yet. Also the gas mileage is terrible I live about 20 minutes out of town and will put $20 in every other day if I only use my truck for going to town and home
Craig 85
Nashville, TN
454/TH-400/NP205
Have you checked the caster? If you are too verticle, it will wander and not want to stay centered. After a turn, does the steering wheel want to re-center itself?
HectorGarcia415
