cold air intakes
Mr87
Jerrit
I've been searching around for an air intake kit that would fit my 1987 gmc sierra r1500. It has a 350 5.7 TBI. The earliest year i could find on K&N was 1988. Has anyone done this or can anyone refer me to an actual kit that should work for my truck and engine?
chengny
Are you talking about the stock snorkel that connects to the hole in the radiator support or some kind of aftermarket "performance" system?
Mr87
Jerrit
yeah I'm looking for an aftermarket performance air intake
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
The best cold air intake you can get, is the stock GM air cleaner. anything else is a waste of money.
chengny
2 X that.
woodsrider250
Fredneck, MD
350-Qjet
I like to call cold air intakes hot air intakes...LOL.
83swb
CT
Hunter
83'
350/th350
The only company that seems to make a true cold air intake is Volant.
Driver4r
Nebraska
Trevor
k10,c20
you can make your own, Get a 2 snorkle air horn from spectre, 2 air intake hoses, and 2 air intake cones. Mount them wherever, and wala cold air intake. probly around 300$ total.
http://www.spectreperformance.com/i...r-dominator-dual-inlet-polished-aluminum.html
http://www.spectreperformance.com/i...omponents/air-duct-hose-black-4-diameter.html
http://www.spectreperformance.com/i...headlight-funnel-rectangular-abs-4-inlet.html
You can't beat a stock air cleaner. They sell kits for modern cars because a lot of them have restrictive intake duct work from the factory. And because they can make money by selling them. In reality, most do nothing at all.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Good sound advice right here... Filters are for sissies. While you're at it, next time you're engine is running, grab the fan belt. I'll bet it works out pretty similar for your fingers.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Seriously, if you want a good "cold air" system, build a box that houses a traditional round filter. Seal it to the bottom of the hood, and to the firewall. Make sure to leave enough space to allow for engine movement. Now cut into the wiper cowl under the hood to allow fresh air into your completely sealed box. No gaudy hoses ran all over the place, and no chance of getting hot underhood air sucked down your intake.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
This took a couple of days and around $25 to make. It provides more air than the intake needs, has an AC Delco filter, and still passes Cali's smog check.
350runner
tx
Ceasar
Closer pics and more info please! That's awesome! I want to make one no more hot air
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
My original thought was to graft a second snorkel onto the housing but with it flipped upside down, that way it would be a symmetrical mirror image of the original. The problem with that is the curve of the snorkel would run the flexible hose right into the master cylinder. By keeping it right side up I was able to get the necessary clearance, it just doesn't look as nice when you open the hood.
The tbi tac (thermostatic air control) door in the snorkel is the issue. When it's closed no air gets through, and even when it's open there are obstructions.
Looking at the housing you can see the snorkel is just a flange tack welded to the base.
I sourced a complete second housing and flexi hose for $10 and removed the snorkel by cutting around the flange wih a die grinder. The tac assy was removed and a flat plate was installed to cover the holes. Some grease was applied to the face of the flange and then pressed against the housing to give me a pattern for the hole to be cut with the die grinder. Four screws and some JB Weld hold it together. I wanted to weld the snorkel on but all I had was oxy/acetylene and it started to distort the metal so I stopped after a couple of tacks were done. Some more JB was used on the bottom of the snorkel where the plate is for a smooth look.
Notice the center opening of the housing above has been enlarged. That was done for the tbi-specific salad bowl mod which eliminates the restrictive choke collar around the throttle body.
Lots of air flow now.
The flexi hose was attached to some sections of 4" abs pipe that was mounted to the radiator support. Some more JB, sanding, and paint was done on the abs so it wouldn't look so cheasy.
Looking through the grill, the new intake gets plenty of fresh air but is tucked behind a headlight so bugs and rain don't have a straight shot at it.
350runner
tx
Ceasar
Thanks! notice any to end power increase?
aaron06
