Boone83K10
- Feb 4, 2013
- Boone, NC
- Benjamin
- K10
Help with timing
Bear with me here this is long post...
I bought an 83 K10 on New Years Day. PO said it originally had a 305 with a Q-jet. It now has a 350 with a Holley 4175 that was swapped in before I bought it. I am going through the truck fixing little things here and there as it is just a play toy/trash hauler.
Here is what I know about the engine.
3970014 block - 68-79 with 2 or 4 bolt depending on what it came out of or 70-76 truck block, depends on what site you look at.
333882 heads - not the best I know. They have been reworked because the VIN stamping on the front pad is gone.
It has power steering and A/C on the driver side of the motor.
The timing cover is not the original 83 because the timing tab in the center is missing. It has no timing tab on it anywhere.
I assume it has an 8 inch(have'nt measured) harmonic balancer that is for the 3970014 block.
I am trying to get this thing tuned up. It runs rich. I bought it at 500 ft elevation and I live at 3500 feet. I have already used a vacuum gauge to tune the idle mixture. I only get 14" of vacuum at idle in park and 11" of vacuum at idle in gear. It is Automatic, and it does have some kind of cam because it thumps hard. It idles good but there is black spots all over the tag and tailgate, and the bumper is black above the tailpipes. I never see any smoke, but it must be running rich to do all that.
I cannot time it because there is no timing tab. I want to start at square one and time the engine then go back and tune the carb. What would be the best way to get a reference point for timing. If I get a 2 oclock timing tab, I can't see it behind the AC and PS. If I get a 12 oclock timing tab, I cannot see the balancer because it stick out and is directly under the water pump.
I want to get this sorted out before I yank the distributor because they used the rubber ends for the intake manifold and it leaks oil, so it will be easier to put it back in if I have the timing tab sorted out.
HELP!!!
HELP!!!
