clunk into reverse or drive
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
been trying to figure out this noise plus another.
1. whines under power, remove foot from accelerator and whine stops.
2. CLUNK when shifting into drive or reverse. it is violent enough to actually make the truck jump a bit.
haven't lifted truck off ground yet to test drive shaft, maybe tomorrow. but with all 4 wheels on the ground it is very solid.
I am hoping they are related. but maybe I don't want that either.
where to start?
MrMarty51
Eastern Montana
Martin
In two wheel drive, front hubs disengaged, grab differential input yoke and try and wiggle it up and down, side to side.
Then, try and turn the yoke, if all is tight there, then check them slip yokes for slop, if Yours has slip yokes.
Jack one wheel off the ground, transmission in park. try turning the one wheel that is on the ground, one direction then the next. Watch the input yoke at the same time, see how far You have to turn a tire before it makes the yoke move.
WillSquared
Arkansas
Will
Similar issues to my own truck. I'd say the rear end is going out. I checked my ujoints and they are in good shape. I luckily have access to a parts truck with the same rear that's in good shape.
Does the whine completely stop or just change tones?
MadOgre
NA
NA
NA
NA
NA
You guys think the clunking into gear is from the rear end going ?
I figure mines gonna blow up one of these days just from being so high mileage and two broken axles along the way, and my trucks been doing the same thing more and more lately and I just finished redoing the carb so ive been hammering it up and down the street to get it set up right, now it seems to really make a good clunk when putting it into gear, but ive been messing with the TV cable too with a new bracket so I wasnt sure if maybe it was just off a little bit with the TV setup, although im not sure how that would make it clunk going into gear ?
And I just put new u joints in the other day so its not u joints
marks86
Latham, NY
Mark
12v Cummins
where to start?
Ive had a 86 k10 700r4 in my family since brand new, and my father told me it clunked into gear since the day he got it
but on a serious note, first check your fluid, low trans fluid will cause hard shifts
-if your trans fluid is nasty dark color replace it with new fluid and filter
-also your TV cable could be not adjusted properly
-how long has it been clunking like this for?
flyboy1100
UsA
me
k1500
Since I got it 3 weeks ago
Sent from my SCH-I605 using Tapatalk
flyboy1100
UsA
me
k1500
Might be a typo in there, try turning the wheel that is off the ground, right?
It looks like they are slip yokes
If I see slop anywhere, what well that mean? Qq
flyboy1100
UsA
me
k1500
Completely stops until hitting gas again
flyboy1100
UsA
me
k1500
hey, how much fluid is supposed to be in the transfer case?
I have a 208 for sure, the id plate is still there! but i can see it is leaking. just fill to the bottom of the fill hole?
edit: 5qts. drained out only about 1.5qts.....
clunk still there, sounds almost like a ringing bell and the truck will actually jump.
MadOgre
NA
NA
NA
NA
NA
Yep I think I got my TV cable set up right and guess what no more clunk when I put it into gear
MadOgre
NA
NA
NA
NA
NA
Yes fill to the top of the top fill plug. you should fill it up drive around and do it again.
MadOgre
NA
NA
NA
NA
NA
Mine leaks from the slip yoke seal back along the tail housing down the main body of the transfer case to the bottom drain plug and then onto my driveway lol, gotta fix that one of these days.
flyboy1100
UsA
me
k1500
o really? i saw those instructions somewhere around here, care to help me out? how long did it take you?
I'm all for readjusting things before dropping $$$ on things like rear ends
Driver4r
Nebraska
Trevor
k10,c20
If theres excess backlash between your 2 gears, it will clunk going into gear. Mine does this and its not really hurting anything unless your those that floor it as your putting it into gear and neutral drop.
But I guess I have enough power i don't have to be like them XD.
MadOgre
NA
NA
NA
NA
NA
flyboy What are you using for a bracket with what carb and manifold ?
504SquareBody
