Cleaning up my wiring. What does this plug go to?
MisterB
Northwest
AJ
GMC K2500 4X4
I have an Edelbrock carb with an electronic choke. The PO wired the red choke wire to the part that's cut. I verified that it only gets power when the key is turned. I cleaned up the connection and redid it, so the truck still works, but I'm wondering what this plug is intended for? Does it go to the oil pressure sending unit? That gauge doesn't work on my cluster. Everything else works though, so I'm a little baffled as to what this plug is for.
Sent from my SM-N975U1 using Tapatalk
78C10BigTen
pennsylvannia
C10 BIG TEN
The plug almost looks like the altenator plug.... dont hold me to that. I ran a red wire with a male blade connector from a key hot fuse in the fuse box out through the firewall to my choke... correct way??? No but it works and i was in a hurry to get it on the road.
RoryH19
Rory
R10 Silverado SWB
Agree, alternator was the first thing I thought of.
MisterB
Northwest
AJ
GMC K2500 4X4
OK, help me understand this then. My alternator is obviously plugged in and working, so why would this plug be available?
Rickf
Grafton NH
1974, 1954 & a 1937
Will it reach the front of the head? Dual alternator set up?
MisterB
Northwest
AJ
GMC K2500 4X4
it might be just barely long enough to reach the front of the head, but not to where my current alternator is.
Here's a Pic from yesterday when I was changing out the valve cover gaskets
MrMarty51
Eastern Montana
Martin
YUP, smog pump or A/C compressor.
MisterB
Northwest
AJ
GMC K2500 4X4
OK guys. Thanks for the info
Sent from my SM-T720 using Tapatalk
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Amazing this place. :burnout:
MisterB
Northwest
AJ
GMC K2500 4X4
No smog pump. More likely AC Compressor.
Even though it's a non AC truck, and always has been?
aaron06
