Chassis saver
truck55
miami
carl
v8
Hi
the chassis saver gloss black is good? is uv protection?
thanks
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Can you be more specific? Are you asking about POR-15, KBS, etc? And welcome to the forums!
truck55
miami
carl
v8
Hello
yes
thanks
da_raabi
FloriDUH
Adam
c30
Soooo.... you talkin about Por-15? I was asking which one lol
thatcanuckguy
sudbury, ontario, canada
colin
c10 stepside
chassis saver is a competitive brand to por 15. imop it is better. the chassis saver gloss black seems to hold up pretty good on what its intended for (chassis, frame, floors ect) not sure how it would last in a direct sunlight application. i have the gloss black under everything on my 66 pontiac, and still looks like the day i painted it. however, the satin black that i used on my rad support, and inner front fenders, turned kinda chaulky after a year. i use this all the time, and would recomend it over por 15 any day. its called chassis saver, from a company called magnet paint. awsome stuff.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I bought some chassis saver with my last monstaliner from them
I was pleased with the monstaliner so I wanted to try the chassis saver but have not used it yet
I have used por 15 and it is some good stuff
unless you plan to use the full amount right away I suggest getting pint cans
the can of por 15 I used had the lid basically welded on from the inside. I had to cut it open to use it.
if you have a small area or plan to do it over time the pint cans would be better less waste. but if you have a big project that you will use it all the quart cans would be the way to go.
504SquareBody
