Center bolt valve cover question
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
the passenger sides has a pcv valve, which I have connected to the carb.
The drivers side has a hole smaller than a pvc grommet. Is there a spec breather that fits it?
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
Pic
Shorty81
Baby Boomer
North West ohio
Darren
Mine has provisions on the driver's side also. But it is the same size as the passenger side. I vent through passenger side and plugged driver's side. These are 1965 valve covers.
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
Pic
On a TBI that goes to the spacer between the filter housing, and the TBI. Just to relieve pressure I suppose. I still have it on mine. If my wife can lift my hood I will get you a picture this afternoon.
Good looking bay by the way.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
All that sexy under there. Looking real good. Lol
1985c20
Torrington, CT
Chuck
Its supposed to have a short piece of metal tube that gets connected to the stock air cleaner so it can draw filtered air into the crankcase. Not sure if there is a push o breather with that small of a diameter on it. Not my truck just a picture I found on google.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
Straight to the spacer with a piece of rubber hose. Just like my pic, but it has an L shaped fitting stuck to it. I have a bunch of these, dont know why. They are not a necessity.
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
Ummm. I was trying to see if I could find some type of breather, but like mentioned, it’s a smaller hole. I thought about a second pcv valve, but that also is too big.
Maybe I need to hit the yard and see if I can find that tube and modify it for a breather.
Thanks for the help.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
Sorry. Pills have me working in a different world right now. I think you can fit a regular grommet in that hole, and a off the shelf breather of your choice.
You can use a PCV grommet on that side too, and get a breather with the smaller, PCV-sized nipple. That type of breather is a bit harder to find, but Jegs or Summit will have something.
bluex
Spartanburg SC
C15
If you find a breather for it post it, here. I'll be needing one too...
I had bought one at AutoZone back in the day, for my '89 Iroc that the PO had thrown out the factory breather setup. It was probably Spectre brand.
MikeB
North Texas
I used a grommet from a 96-up Vortec engine in that hole along with an aftermarket breather with gauze filter. Eventually found a plastic elbow and hose to connect the valve cover hole to my air cleaner.
I was looking at Summit's website, you can look up valve cover breathers by nipple size. It makes things easy.
MikeB
North Texas
Ah, yes, nipple size. :)
ebob14
