Cargo Light Switch
Soundmound
North Central Washington
Dave
Scottsdale
So this is embarrassing. I'm having trouble locating my cargo switch connector. I can see the dome wires and their corresponding connectors hanging in the C pillar, but haven't been able to snag the one for cargo. Checked the Chiltons and nothing showing the route. I don't want to yank on 39 year old wires blindly so thought I'd ask.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
It should run the same path as the dome. Pull your door sill plates off and check from there. You should be able to see them in the corner of the cab I believe.
Ellie Niner
Tucson, AZ
Tory
K10 Silverado
LE9 305
The cargo light harness plugs into the dome light harness at the base of the C-pillar, then runs up separately from the dome light. The two harnesses usually take the same general path, but can move around separately from each other. You should be able to fish around in the cargo light switch hole with a bent piece of baling wire and snag it. There are a few pictures in the linked thread from when I completed the install of a cargo light in mine awhile back.
Cargo light install
PrairieDrifter
North Dakota
Mason
Ah yes, I believe I've seen that pigtail connector hanging out a few inches up in the pillar. Maybe it was the other way around. I can't remember now.
Soundmound
Dave
Scottsdale
Thanks all! Once I could tell there was a separate pigtail, I knew it got sucked up into the roof by the PO. Had to pull the cargo light assembly to free up the wiring and pull it back down. It's in now!
jp wessels
