Cant remove hub. Please help
Boltrunner
Odin mn
Shane
V20
Sitting here trying to get my hub off so i can replace my u joint. I have the cover removed but now cant get the hub off. I took off the smap ring.
dvdswan
Port Orchard, WA
Dave
There are 2 rings, an inner and outer. Internal snap ring catches on the hub and the axle shaft snap ring which catches on the axle shaft.
It looks like you axle shaft ring is off, its hard to tell if the Internal one is there or not. You may have to pull really hard on the lock mechanism to get it out. Maybe apply a little heat to the hub to get it to expand a little.
Boltrunner
Odin mn
Shane
V20
It wasbthe snap ring around the perimeter of the hub that was holding me up. Thanks for the diagram
Craig 85
Nashville, TN
454/TH-400/NP205
Look in this area for a thin snap ring.
Boltrunner
Odin mn
Shane
V20
Found it. The opening was 180° from where you indicated. There was a decent coating of grease for me to dig around. Cant complain too much tho. I was kind of worried tearing into it that stuff would be dry and dusty from being a ranch truck in its previous life. But all seems ok inside.
Boltrunner
Odin mn
Shane
V20
Haha no. I have the wrong 4wd socket. Its a 80 mile round trip to the parts stores
ajd89
Central Michigan
andrew
Ive used a big flat screw driver and a hammer before to get them off not thats the right way but it worked.
Boltrunner
Odin mn
Shane
V20
Thought about it. But my pockets cant afford to mess anything more than the u joint already lol. I looked at it a little when i was under there and im almost thinking that it is not useable. Ill post a pic of it when i get it out.
dvdswan
Port Orchard, WA
Dave
Generally, the outer lock nut is just snugged up to the lock ring. That will just slide straight out as it is keyed to the groove then the adjuster nut for the bearing tension. A 1/4" tip screwdriver will work in the slot and use a hammer on the stem to break loose. Unless, the PO or shop used an air gun on it. which is a bad thing.
Boltrunner
Odin mn
Shane
V20
I got the outer one out using leverage with a small pry bar. The socket i have is the correct size but it has the prongs surrounded with a flange so it keeps the socket from sliding down. I bought it for a ford i worked on a while ago.
It's actually supposed to be far more than just snug. The factory service manual calls for some crazy amount of torque that I never remember what it is. I normally just lean on the breaker bar real good to make sure it's tight enough.
dvdswan
Port Orchard, WA
Dave
Just looked it up and they said 160 ftlbs. Holy Hannah.
Boltrunner
Odin mn
Shane
V20
Good to know.
78C10BigTen
pennsylvannia
C10 BIG TEN
Sounds like how i tighten my lug nuts....
krogers98gmc
