Can someone point me to threads on 350 vs 400 cid
Carb'ed Vortec 350
I'd say run the 400. If you don't want it I'll drive over to AZ and buy it off you.
WHEELMAN
HICKORY TAVERN SC
BILL
454 v8
The 400 motor. Is crap.just a scam.to ad some pickup.to a new big car.like a Caprice or impala
If I remember right.they took a 350 V8 block and bored it out.making the cylinder,s
Simees..the center of the cylinder.is thin and the head gaskets would blow and the engine.would blow a gap
From cylinder.the engines are trash.they run warm get hot and it all goes south
Stick with the 350 V8 or go with the 454 V8. Well if you want too cruise.or go with the defective 400 and be wrenching
Don't even think about.using a 400 V8 in a boat.i have never herd of any one that had a 400 V8 hold up.
CSFJ
you also think that the early 700r4 is a strong transmission. I think it's time you stopped drinking paint thinner.
Dooley
North Coast
RW
V30
All of my 400's held up.
They worked hard and did their job.
morrow07
San Mateo, Ca
Ryan
Cheyenne - V2500
That's funny. I would mind taking you for a ride in my 77 and scaring the **** out of you, all will never going over a 195゚ lol
If there's a thread about 400's around here, wheelman is sure to sniff it out.
h3adbang3r14
Ohio
markus
k20
sbc 400 from 78 k30
Ran a 350 and a 400 in same truck two different plow seasons the 400 was way better with better low end torque number for long pushes of heavy wet snow in my 81 k20 long box with sm465 11"dual friction clutch np208 and 4.10s running 33s in granny 4 4lo it creeped at 1.5 mph but it had plenty of power to move mountains of snow and ice out of the way but wasn't as friendly at gas pump when driven on highway at 70 mph think that was my carb tuning more than anything though
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
400 is my choice. as previously stated, plenty of torque as is.
75Monza
Colville, Washington
K30, K20, K20
I like the 400 too, built with attention and not just a slapped together backyard job...great torque for a plow truck. I've always felt the 400 got a bad rap, part from people trying to wind it like a 327 and part from getting worked on like any other sbc...biggest sin was swapping heads with no clue what steam holes are or how to add them to non-400 heads. My preference is the 509 casting block because it is the higher nickel content, and a 2 bolt block because there is more meat there to drill it to a 4 bolt splayed. I prefer to keep them around .030, will run a .040 but nervous above that. Also prefer decking the block and studs for the heads, and internal balanced crank. For any 400, as long as I've kept a good cooling system, they never let me down.
71RAT
Deerfield NH
Kirk
K20 Scottsdale
No replacement for displacement !
Accept, artificial atmosphere !
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I would never accept artificial atmosphere, except when in a hypoxic state.
TravisB
Travis
I have a 400 in an 84 k10. Didn't know I did until one of the heads cracked and 350 heads aren't the same (you can make them work with some machine work which is what we did). It pulls great but the truck has 2.9x gears so it really needs it. haha
The only issues I have had with it were probably poor maintenance related. It fouls plugs a lot, diesels at times, and the starter makes a horrible racket. It's been pulling loads and driving around since 92 or so though on our piss poor maintenance so that's something.
View media item 7970View media item 7969View media item 7968
68post
Indianapolis
Tim
454, TBD
TravisB,
I hope you're using a BIG trans cooler pulling those loads with 2.xx something gears !
Half ton ?? How are your brakes !?
TravisB
Travis
TravisB,
Use those photos of what not to do lol. The brakes are okay for what it is but without trailer brakes I wouldn't have even started. Those were all close to home hauls. Using the factory cooler in the radiator but it has a TH350 instead of that junky 700r4 of the same years. I have more trouble from the rear axle. It has been replaced twice and instead of just getting better gears we fix this one repeatedly... not my idea. Dad knows best! haha
Garcjay
