Brake Question for you square body gurus.
riggs
erlanger ky
jonathan
just did a search and couldnt find an answer.
i went and bought new brake pads and new calipers for my 87. the driveside went on without to much of a pia.
now the passenger side im having major issues. seems like a stupid question but it cant fiqure it out.
i put the brakes inside the caliper and went to put them onto the spindle and they just will not slide up enough for the pins to go into place. i know this may sound strange but it seems as if the brake pads have to much padding on them... lol. but ive tried everything. the caliper is closed completly and the rotors arent new but still have a lot of meat left on them....
i sure would appreciate all inputs...
i needed to get the truck out of the garage due to brake fluid all over the place and wanted to get it cleaned up. so i put the old pads back on the passenger side and they went on without an issue of course.
J Knight
Baytown TX
82 Chevy
350ci
Did you push the two caliper bolt sleeves back out?
J Knight
Baytown TX
82 Chevy
350ci
I would double check that the caliper is fully colapsed and the pads are in flush and if it still wont go on I would compare/measure the rotors/calipers/pads and make sure all things are equal.
riggs
erlanger ky
jonathan
will do i double checked a bazillion times on the caliper it was fully closed, thats the way it came from oreillys.
when i went to the parts house the first time to get driver side caliper he asked which brake system i had, this last time a different guy just pulled a caliper for 87 1/2 ton and didnt ask which brake system i had.... that might be the issue, updates to come tomorrow just thought id ask you gurus first....
thanks
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
thanks
he gave you a 2wd caliper.
J Knight
Baytown TX
82 Chevy
350ci
thanks
Maybe he gave you a caliper for a 1in rotor when you need a 1 1/4in or vise versa.
riggs
erlanger ky
jonathan
so there is a difference in the opening on the caliper, i swear parts houses within the northern ky area dont know their ass from a hole in the ground :flipthebird:
Illuminati
C
K10/Silverado
350 4bbl
A lot of 'em don't. A lot of times I bring parts with me to show them what I need instead of arbitrarily grabbing ****.
I also agree with the other fellas...probably got the 2wd stuff instead of 4x4 is that's whatcha got.
riggs
erlanger ky
jonathan
my truck is a two wheel drive..... guess ill have to pull the truck back apart tomorrow and take another trip to oreillys....
Yeah, the parts idiot gave you the wrong caliper.
Jims86
Patterson,Ca
5.7 TBI
Your vehicle info at the left says k10
burbboysgc
Columbus, Ohio
Chevy
I've had the same thing happen to me when I changed my brakes. I always double check any part I get now, even when it's from a parts store with a better reputation. Aint nothin worse than wasting time trying to put the wrong part on. I think I cussed for about 2 hours before I figured this can't be the right part.
riggs
erlanger ky
jonathan
it sure does say k10 i'll be switching that i set up my account via my smartfart phone, guess i aint to smart at using it.... :)
well gurus i fiqured it out, jack asses at parts house sold me the wrong caliper. he sold me a caliper for a different brake system....
its all back together now..
thanks
WhatsUpBeaches
