Blazer or Suburban tank for relocation?
cooperhw
Mesa AZ
Wayne
C-10, K-20, C-20
5.7L
Just thought I would ask the question of what works between the rear framerails on my 79 C10? I keep hearing blazer, but I actually have a suburban stashed on my property in the mountains (if I ever get up there). I am not against buying a new tank, but would hate to if the one in my 86 suburban would work. Figured there are guys on here who have already "been there, dunnn that", so I thought I would ask the experts.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Burban 40 gallon might be a tight squeeze for what your building Blazer tank is only 25 gallon but will still sit below the frame a bit. It might be perfect for you tho. with your false floor. You could put the pinch seam above the frame.
cooperhw
Mesa AZ
Wayne
C-10, K-20, C-20
5.7L
I could and might. Probable a 25 gal. is enough for me. I would like to save that space above for my compressor and air tanks if I can.
Thanks to all who responded.
Camar068
10 yrs Air Force
start from the end of the post and work your way back. They are working on getting the pics fixed. It's a photobucket thing, which forces, those who use it, to update the pics.
Blazer tanks come in 25 and 31 gallon sizes. One is just a little deeper than the other.
Burb tanks come in 31 and 40 gallon sizes. The 40 gallon is a longer tank and reportedly is not a good fit in pickups. Although the Burb is roughly the same length as a longbed pickup, so I'm not convinced.
Blazer/Burb 31 gallon tanks are the same tank.
75Monza
Colville, Washington
K30, K20, K20
Was the 40 gallon Burb tank the one that came with the diesel or did it also come in a gas application?
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
V10 Suburban/V1500 Suburban/M35 bobbed w/dump/M1010
5.7/5.7/LDT 465-1c/6.2 diesel
My M1009, military blazer, with a 6.2 diesel had a 41 gal tank.
Must of been an old aftermarket high capacity tank that was deeper. A factory 31 gallon tank is a hard enough squeeze into a K5, it's basically shoved right up against the back bumper.
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
It could have been the same size front to back and side to side and just deeper. It had a pretty heavy plate under it too. Both of my Suburbans have a 41 gallon tank also.
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
It was a stock factory tank but probably specified by the government for the M1009. It was used mostly for a scout vehicle and could do more then 500 miles easily on a tankful of diesel. I wish they had put a OD transmission in them though.
Georgeb
Wisconsin
George
K10 Burb Z71
The 31 fits nicely in a C10. And you will enjoy the added capacity over the 26.
cooperhw
Mesa AZ
Wayne
C-10, K-20, C-20
5.7L
Looks like I will have to have a custom tank made cause the distance from the rear crossmember to the front edge of the rear of my c-notch will not let me put a stock tank in it otherwise. Have to search around.
87POPS
