bed side panel removal
crpntr78
Missouri
Hello all. Searched the forums for this and all I found was how to remove the front bed panel. I'm trying to remove the driver side bed skin. I have all the spot welds drilled out and most of the panel loose but there is something holding it at the tail light pocket assembly. I don't see any more spot welds and so can't tell whats holding it. Any help would be appreciated. Thanks
Swims350
Logan WV
none
you have a bed side skin? Most of the time they are full bolt on sides. I've never taken one with with spot welds, I unbolted them down the front bed panel, along the floor in front and behind the wheel well, all up inside the well where the bedside meets the actual inner tub, and the 2 on the back and 2 on the front bolts under the rear stake pocket in back, followed by 2 spot welds or tacks maybe more where the stake pocket meets the floor and down in the area where the side meets the tailpan, usually easy to spot.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I skinned this one when I made it into a wall hanger, I drilled the spot welds in front of the rear stake pocket and the inside came out, the rear stake pocket/area where tailgate hardware mounts is separate of the inner skin and is folded and spot welded I think.
crpntr78
Missouri
Yeah, I have all the spot welds drilled out that I can find. It appears to be hanging up in the area of the tail light housing but I don't see any spot welds there. I'll keep at it and hopefully I'll get it off.
crpntr78
Missouri
Got it off fellas. As I was unceremoniously banging things with hammer and chisel (in the wrong spot) the rest of the spot welds manifested themselves so I drilled them out and off she came. Thanks for all in-put.
crpntr78
Missouri
I have pics just haven't loaded them yet.
crpntr78
Missouri
Here are the promised pics of said bedside skin. There were spot welds about every 2" along the inside bedrail, a dozen or so along the front of the bed and several along the back by the tail light. Those were the ones holding me up as they were on the outside of the bed where they were painted over so well I couldn't tell they were there. First pic is of the outside of the inside bed side.
matkes77
Austin, TX
so I don't have pics, but my bed is a cheese grater....rusty holes everywhere. Is it feasible to just replace the bed floor if sides aren't too bad or is it just better finding a donor SWB bed?
Swims350
Logan WV
none
you can swap bed floors if you can find one. They repop them now if you got the cash
Swims350
Logan WV
none
I gotta ask why skin a bed side and not just unbolt and bolt on another? Or really why are you removing the skin? I assumed rust or dents or replacement
crpntr78
Missouri
Well, to answer that question. I'm working from a low ball budget. I could have bought new bed sides from LMC but they wanted $350.00 each and I only paid 1500.00 for the whole truck. Can't see paying half the total cost for just 2 bedsides. So I cut out the section over the wheel arch and welded in a patch panel. There was a dent close to the front of the bed that I couldn't access with skin on so I removed it to pop that dent out and fix the crease in the body line. Not going for full resto or show quality. just want it to look good on a budget.
Swims350
Logan WV
none
understood, alot of work for a dent. I would have got the $100 HF stud welder dent puller
Wilburn Martin
Northport, Alabama
Wilburn
C20 3+3
I have the same thing happening with one of my trucks. PO beat the sides on anything that came by apparently. I bought it and a parts truck for $1,500. I'm taking the bed sides off and swapping them currently
aaron06
