Any one running a 4L85?
Battlac40
New Mexico
James
K1500 Sierra Classic
4x4 4L85s anyone? Vs the 4L70? Vs 6060 ? Craving some overdrive !
But refuse to buy a 700r4.
:boxing:
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I have a 4L80, an 85 just has a 5 pinion planetary, totally unnecessary. The 70 is pointless.
They'll all need a standalone controller if you're not running an LS engine.
Battlac40
New Mexico
James
How do you like your 1st gear?
What torque converter are you running?
Are you using the flat or 'w' cross-member; what transfer case?
Jrgunn5150
Ionia Mi
J.R.
6.slow
Turbo 6.0, first gear irrelevant.
Aftermarket crossmember, Tejas.
No transfercase, C10.
Battlac40
New Mexico
James
I edited the post my intention is 4x4 related, sorry brotha; complicates the issue.
rpcraft
Robert
LS 6.0 364 CID
If you want to go 4l80 (or 4l85 whatever) you will need a W x-member and a North west fabs 6 bolt adapter for your tcase. I have been told that you can use the original 4l80E T-case adapter but I have yet to have the pieces in my shop to test the waters. (It's a WIP) It's commonly known if you are having a hard time finding a 4wd 4l80e for cheap you can get a 2wd unit out of certain years of 2500 work vans that had a 6.0 in them, it just takes plugging a lube hole and then shortening the shaft (I recomend using precision tools to measure and cut once rather than internet booshwa). You can tell it is the right unit if it has the 32 splines all the way from the beginning to the inner seal (meaning you have to take off the tailshaft housing to eyeball it and some people freak out about you doing that to their for sell unit.
As previously mentioned you need either a stand-alone controller or a LS PCM to control it, and short of doing the LS swap (which is what I have going on) I am not familiar with using the LS PCM on an older TBI truck but I am aware it has been done with some degree of success.
rpcraft
Robert
LS 6.0 364 CID
Also, you need to ensure your Tcase has a 32 spline input shaft
yevgenievich
Viktor
sad
very sad
less sad
4l80e should be fine and easier to find. 4l70e has application where space is limited.
For me first gear works fine. All stock 4l80e with 241 t case . 411 ls computer can be set for stand alone. It is same ecm that was used on ls and old vortec motors at the same time and has been proven to work in various conversions.( Including controlling tpi, lt1 and other things)
Battlac40
New Mexico
James
Been wrestling with the idea of a 4l65e. I have Both a 205 and a built 208 in 2 different trucks. I am wrighting my opions.
I am aware about any of the 4L family trans. Need stand alone or LS.
I read that the 4L85(s)are gen 1 block 'friendly'.
Trying to dig deeper ..
The tranzilla 6060 seems nasty.
27 or 32 ; I could always convert the input o n the 208 to a 32 (gaining a slip yoke).
But I am definitely lacking a w-style crossmember .
78ALB
