Another backspacing / offset question
Italianwagon
Washington
Steve
V20 Suburban
Ok narrowed it down to two rims and sizes.
87 3/4 suburban with 2 inch lift: Looking to get 33s on the burb.
16x8 rims with a -12 offset and 4 in backspacing. Will they fit?
Or
17x9 rims with 0 offset and 5 backspacing? Will they fit?
Depends on your definition of 'fit', your front spring rate and also your driving style.
But 'yes' to both.
If you run the normal 305/70 or 33x12.5 then you will most likely get some minor rubbing if your springs are soft and/or you take it off the pavement and basic gravel roads.
On the 16x8, you could run a narrower 285/75 that is still a 33" size but will be less likely to need minor fender trimming. But that's not a very impressive size, lol. It fits many modern trucks in stock condition.
Snoots
Roger
Jimmy Sierra
Italianwagon
Washington
Steve
V20 Suburban
Got ya. So a 5 in backspacing will work.
Italianwagon
Washington
Steve
V20 Suburban
Any body now the offset and backspacing on the 8 lug steel wheels on these trucks?
The 16" steel wheels were only 6.5" wide. I seem to recall a backspacing of about 3.75", but can measure one tomorrow to be sure.
Washington
Anything close to
You’re correct. And they’re 0 offset.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
These wheels came on my K30. They are the 2000 and up PY0 wheels. Here's the info on them. The tires were 265/75/16 and did not hit the front springs.
RPO - PYO
Rim 16x 6.5
Lug 8 x 6.5
Offset +29mm
Backspace 4.875"
Photo #3 is Frankenchevy's truck. 16x8" 4" BS 285/75/16. I know his truck does not have a lift, but being a K30 it's 2" taller than yours.
SquareRoot
RPO - PYO
Rim 16x 6.5
Lug 8 x 6.5
Offset +29mm
Backspace 4.875"
Sexy beasts!
Gord
