Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
Here's what I did today. I followed the excess wiring I don't need anymore. The less wiring to have something go wrong the better.
Below is what that splice looks like that comes from the alternator, and in ya'll's case goes into the engine compartment harness. There are three wires: center of the photo, #12 red, #12 white, and a #16 brown. The red wire is spliced in two. One goes in the cab for 12volt power. And may go to the battery cable at the starter. The white wire is connected to another #12 red and goes to the junction block on the firewall. The #16 brn-25 goes to the firewall wire block and goes inside where it comes out of the interior wire block as a #24 brn-130 which is the exciter wire that goes to the #12 orange wire at the ignition switch, black plug. That's the one that caught fire in my truck. And another wire in the same hole as a #16 brn-25 that goes to the alternator light on the instrument panel as a red light. This light provides resistance so the alternator will start making voltage. When you start your truck that light comes on to tell you the field windings are being energized. After a moment or two that light goes out. If it doesn't the alternator has a problem, usually the voltage regulator.
The photo below are three wires in the center of the photo that are stretched out. I no long needed them and didn't from the time I rebuilt my truck. I just never removed them from the harness, to lazy I guess until I had a real problem. Now it's time to take them out and any other wire I don't need. The #16 green wire is what's left from the old idle stop solenoid that went to the two bbl. that used to be on the stock engine. The #20 tan wire went to the old A/C temp. switch. I bought this truck in '81 and it had A/C until six months later when the compressor froze up. I took it out and this is a left over wire. The #20 black wire with the white stripe is what's left from the old stock amp meter gauge I had in the instrument panel. It didn't work so when I put in the Autometer amp gauge I had to rewire it the way Autometer said using #10 wires. Besides my old amp gauge didn't work anyway and I couldn't use the original wiring for the Autometer gauge and I left the old wire, until today. I cut it out along with those other wires to finally get rid of it altogether.
If you have factory amp gauge you ought to have wires down on your starter where you'll see two of those plastic fusible links. There should be a #16 black wire that goes into the link and comes out as a #20 orange wire that either goes to a small screw between the big starter ground wire and where your battery wire bolts to. In the photo below is what the other end looks like that goes to the wire block in the firewall. It has a 10 amp fuse in one of these kinds of holders. I cut all that out today from the starter and over to the block on the firewall. Here's what it looks like.
Below is my new terminal end I put on the #12 red power wire on the alternator. And, @SirRobyn0 I'm taking your advice and putting in that new alternator I had put back as a spare instead of just electrically checking out the old alternator, which I did the other night that was in there when the fire occurred. It's a newer kind of alternator like mine. It even has needle bearings on the bottom of ther case halves. My old alternator cases have just bushing bearings in it that I had just replaced when I rebuilt it six months ago.
