Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
Last night I posted a problem I had with the alternator signal wire up on the ignition switch frying, like it must have caught fire because it was melted to a bunch of other wires it was touching in the bundle. Well, they are mostly all okay after I had a chance to unstick them yesterday and examine them all from the firewall to wherever they all went. So I unplug the black plug up on the ignition switch and pull those wires over the steering column so I could get a clear look at what was going on. Looking at the schematic it shows that a #12 orange wire, (ign.#3) and that signal wire are on a terminal end together in the plug. Also, yesterday I uncovered the wires that go to the bulkhead block that pass wires through the firewall to locate the alt. signal wire and do a continuity check on it to make sure the one I was testing was the one that wnet to the alternator, I have a two wire alt. On that black plug there is the #12 orange (ignition needed at start), #12 red (same), and a little bitty #20 brown wire which is the brake warning switch (ign. #3 same as above).
Yep, that #16 brn. wire was the one. I just wanted to verify that it hadn't gone up in smoke when the one inside caught on fire. No, it was fine. All the engine compartment wires are perfect. So back inside the cab. Today i got all my detailed paper on the wiring of the truck, by the way I have a '74 C10 all hopped up and modified with full Autometer gauges and i rebuilt the whole truck from bumper to bumper frame off. I didn't mod. the wiring other than taking every single wire removed the factory tape and cleaned all the wires from start to finish, and aircraft style reorganized all the wiring and put plastic corrigate on all of it except under the dash, from bumper to bumper. That was all back in 1995-'96. Everything has been perfect up to now.
Today looking at the schematic's and detailed drawings I determined that I don't think that little air compressor had anything to do with that one wire catching fire.
Now here's where I need ya'll's help. That one single wire catching fire was either a problem with the alternator, or the ignition switch. What do you think, and why? But I can't figure why would that one wire catch fire when no fuses were blown, no other wires caught fire although when smoke started coming out from under the dash a block from the house, I pulled over, got out and looked under the dash. The first thing I did was grab hold of the ignition wires, I don't know why, that come out from the fuse block and go up the firewall in a group, I did mine that way to be able to identify those that go to the ignition switch, and up to the ignition switch. When I did, that whole group of wires was hot!! But as I discovered the only wire that actually got hot enough to burn was the alt. signal wire. None of the wires looks like they got hot enough to distort the insulation, turn brown/black, or any other sign of heat. Just the alt. signal wire.
What do you all think could have happened and why because I'm either going to have to replace the alternator and/or the ignition switch as well. But what do you think could have happened and I'm sure it's because I don't fully understand the operation of the system and I've been studying all day and I still can't figure it out. I understand it well enough to trouble shoot most problems but this problem doesn't make any sense at all.
