Air blowing out dash vents even when defrost or heat is selected?
mcarlo86
ND
Suburban
Has anyone had a situation where the air is always blowing out the dash vents no matter what position the heater control is on? I can put it on defrost and some air comes out the defrost vents, but most comes out the dash vents. Then if I put it on heat, some air will come out the floor and most comes out the dash vents. I'm assuming there is a door that must be stuck open behind the dash somewhere?
thecantaloupeman
US
Dawson
C20 Silverado Camper Special
My truck does this too. IIRC it was a feature that allowed outside air to circulate in the cabin when the blower isn’t on. It’s always on at a very low speed.
MisterB
Northwest
AJ
GMC K2500 4X4
The fan blower motor is always on when the key is in the on position. You can test it by turning the control all the way off, and then turn the key to on, and you'll hear the blower motor still spinning slowly.
It's likely a feature to help circulate air in the cab so that exhaust fumes aren't as much of a problem
Sent from my SM-N975U1 using Tapatalk
Yes. Ever since I bought my '88, it has done this. Every mode works well, but air flow always comes out the vents too. I never have been able to figure out what was wrong. More recently, my '78 began doing this, but the other modes hardly had any airflow. In this case, the vacuum line to the reservoir bottle had deteriorated.
chengny
Check the condition of this part. It's called the "diverter Valve link connector". It breaks frequently- and when it does, the link is unable to move the diverter valve into the fully closed position.
Result is undesired airflow up to the dash vents.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Is it normal to get some airflow out of the dash vents when set on Heat ?
Blows hard out of the floor ducts, but a little comes out the vents, too.
Not gonna change it- keeps my hands warm:), but I am curious.
Normal? One might say yes, lol. But I don't think it's what GM intended. Most of my trucks have not done it.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
The 4Runner does that, too, but only out of the outside vents. That is by design, though, not age related vacuum actuator weakness. :p
Reinovator
N arizona
c-15
I have had three trucks do this the white plastic piece was broken on on Two had to make one for them But they may be available aftermarket now and you can use home door insulation to help close it off for more air flow this worked on one of mine, if you wish.
Charlie7985
Decatur, AL
Charlie
I had this same problem and it was from the actuator that controlled that door having a slight leak that kept it from closing the door all the way. You can test it by pulling the rubber piece where all of the vacuum lines connect to the back of the dash controls off. Then plug a hand held vacuum pump into each line one at a time, pump them up a little and see if they hold. You will have to pump it a few times to fully deflate the actuator before it will start to hold.
DucatiDave
