Aftermarket Window Crank Handles
sonicbluezx3
North Carolina
Steven
Just curious, but has anyone ever used something like this for window cranks instead of the plastic stock ones?
http://www.ebay.com/itm/ALUMINUM-SI...822&pid=100011&prg=1005&rk=1&sd=370646827353&
I've always liked this style and it will go nicely with my interior (black and chrome). It looks like it would eliminate the little clip that is a PITA to pull out and would attach with set screws.
Just trying to do some research before buying them! Thanks for any input.
79K10
Sacramento,ca
Ryan
350/th350
those are nice! id rock those. i dont see why they wouldnt work
robert8096
Goose Creek SC
Robert
They look good and they are universal so I would give them a shot. The only thing I would do is try to drill a small detent in the window mech shaft so that the set screws would have a good bite. Then I would put a little blue lock tight on the set screws.
My brother in law bought the same cranks for his old Beetle, I installed them and it was very easy. They are holding up just fine.
BTW, there's a cheap tool available that easily removes the stock spring clip.
whiplash889
saegertown pa
joseph
k20
lmc truck has the same thing i bought them for my truck they work great love them
I bought those very ones, and they were crap. Yes they are universal, and if you window has any kind of drag, from the window rubber, they will break, that's why I don't have them any more. I put new window rubber in both doors, and I guess because they are new and not broke in, my cranks lasted about a month. Yes I was bummed, because they look really good.
whiplash889
saegertown pa
joseph
k20
the onces from lmc truck are aluminum works great in my k30 crew
static_86
Ontario
ya i bought these too and yes they are cheap mine didnt even come with the right attachment so i had to drill mine out and then gorilla glue them on. they look good tho with a bit of modification they can work. just make sure ur window reg is oiled up nice
85 C10
Buaffalo NY
Jason
look nice I would use them if I did not have power windows
Steveo75
