Ac/heat high speed fan not working
JZCracker
Idaho
K20 FLEETSIDE
Help.. I am in no way a Gearhead and I'm learning as I go. All of a sudden my high speed AC fan is not working. It works fine on low and medium but when I switch it to high I get no air at all. I did some internet research and replaced the high speed fan relay under the hood and verified that my AC heater control switch is also working fine. Any ideas?
chengny
When operating the blower on the LO/MED1/MED2 settings, power to it is supplied from the fuse labeled HTR AC which is located in the normal fuse block under the dash. It gets to the blower via the resistor stack
However, when the HI setting is selected, the power to the blower motor windings is direct from the battery. Moving the fan speed controller to HI only actuates the relay's coil. Then when relay pulls in, the blower gets full battery voltage.
In order for that HI SPD circuit to work, you need a power supply from the firewall junction block to the fan relay (it gets there on a fat red wire)also the relay's coil must be operating and properly grounded. Since you installed a new relay, you can probably eliminate the coil.
That leaves the main power feed on the red wire and the ground lead for the coil. When in any other speed than HI the coil is de-energized and in the default position. All speed regulation occurs in the dash switch and resistor stack.
There is 30 amp inline fuse spliced into the main supply - probably right near the junction block. The wiring dwgs show it located where the red lead changes to an orange lead - that orange one is what ultimately connects to the relay.
Fuse okay and power getting to the relay - check the ground lead.
My '75 had the 30 amp inline fuse connecting the junction block to the fan, and the fuse kept overheating and frying the fuse holder. I finally bought a 30 amp blade fuse holder and spliced it in to replace the old holder - no more problems.
Kdsooner
Norman OK
Kevin
GMC C1500 Sierra Classic
Do y'all think this is the case for an 81 with factory air? I've replaced both relays on the heater box to no avail.
Does your truck have a separate 30 amp fuse for the high speed on the blower? On the older trucks it’s very easy to see because the power wire, with fuse holder, runs along the top of the firewall in the engine compartment. It runs from the power junction next to the brake booster, over to the high speed blower relay.
Troubleshoot the issue, don't just throw parts at it. Do you have voltage at the power feed to the relays? Go to the reference library and download the manual PDF's for your year truck and then check the wires to see where you have a disconnect or fault.
Kdsooner
Norman OK
Kevin
Sorry haven't spent much time on the site. Where would I find the reference library and manual pdfs?
aaron06
