A/C and blowing fuses
Brownie82C10
Winter Haven, Fla.
Joe
Chevy C10
4.1L Inline 6
I have a 1982 Chevy C10 pickup with the straight-6 engine and a mostly operational A/C system. The A/C-heater regulator is an aftermarket model, purchased several years ago from LMC Truck. The A/C system worked up until about nine months ago, when it suddenly stopped working. After a brief investigation, I discovered that the 20-amp blade fuse blows whenever the regulator is switched to cooling or defrosting. With a good fuse, the heating and venting operations work fine.
What do I have here — a short or ground problem at the regulator or somewhere under the hood? What's the next step in the problem solving?
Thanks.
Dave M
Banned
Australia
Dave
Check the clutch on the a/c compressor, unplug the wire at the compressor, then try it again.
Brownie82C10
Winter Haven, Fla.
Joe
Chevy C10
4.1L Inline 6
OK, I tried the A/C controls with the wire connector unplugged from the compressor. The fuse blew again when I switched the lever from VENT to AIR COND. What's next with the troubleshooting? Thanks.
Dave M
Banned
Australia
Dave
It's hard to diagnose when you can't see what your working with, or not familiar with the actual system you have. Bit of a hit and miss, keep disconnecting the various components and also look for any damaged wiring.
Brownie82C10
Winter Haven, Fla.
Joe
Chevy C10
4.1L Inline 6
Thanks. I saw another thread that suggested a ground/short wire problem between the A/C controls and the fuse block. I'll focus on that first.
Lost Sheep
