99 night train
yevgenievich
Viktor
sad
very sad
less sad
Checked primary oil level, clutch adjustment and chain adjustment, all ended being ok. Brake light switch is acting up and found a big hack with battery attachment. Cleaned, and removed accessory plug that was installed.
Also having hard time getting left tank fill to actually open. And there is oil leaking somewhere, but I guess not too bad.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Was the body work polished in the first pictures you posted?
yevgenievich
Viktor
sad
very sad
less sad
It is some sort of chrome paint, which will be a pain to touch up on the tank. Will either spray a stripe/pattern on the sides of the tank or leave it alone
81Bart
Illinois
Bart
C10 LWB
Are you sure the left tank opens?
yevgenievich
Viktor
sad
very sad
less sad
I was wondering about that, but right one has R label on it, and that is the only setting on fuel selector that can get fuel. There is also a clear separation inside of the tank
Big Chip
Michigan
Kevin
C35
I think that’s just a fake cap If I remember correctly. If you can get 5+ gallons in it your getting to both sides of the tank.
81Bart
Illinois
Bart
C10 LWB
does it turn at all or click or anything? is it left handed thread?
i ride an 85 Fat Bob and my gas caps are threaded opposite each other and if i don't push down hard like on a medicine bottle and turn they just spin and click.
yevgenievich
Viktor
sad
very sad
less sad
It is opposite thread. Thanks for the tip.
Grumpy Grizzly
Kalispell, MT
Josh
Suburban 1500
Had a night train myself. the left side cap is supposed to be your gas gauge and not meant to open but with yours being custom ????, also like someone else said if you are filling to 5 gallons you are getting to both tanks.
If you are still having issues then look a the cross over hose near the front of the tank. It goes under the frame rail. That might be kinked or the tubes got crimped.
yevgenievich
Viktor
sad
very sad
less sad
I can't leave things alone apparently
yevgenievich
Viktor
sad
very sad
less sad
what color are you painting it?
Just doing the sides in black. Will see how it looks overall. Maybe repaint the whole thing if I keep it long enough.
81Bart
Illinois
Bart
C10 LWB
black will definitely contrast the shiny faux chrome tins.
Rusty Nail
Rusty
350sbc
'91 Bay-bee!
PapaBear8486
