87 suburban radiator
Wallace6
Wyoming
Ray
Suburban
So I have a 87 suburban that was originally a 6.2 but has been swapped to a 350 at some point. Working on the cooling system at this point,did hoses and a WP and now it appears I need a radiator. Looks to have the 17" core.
I was seriously thinking about getting an aluminum with electric fans from eBay.
Opinions very welcome and anything that might hinder me like a cts or something I'm not thinking about,even alt upgrades,I do have dual batteries but probably need to think about a relay and temp setting switch? I dunno so opinions very welcome
Thanks
RustyPile
Elkhart, TX
Nick
1983 GMC
350 SBC
I put a Derale dual fan with their stainless steel shroud, aluminum 4 core radiator on my truck and relays and controllers for both fans.. And it still runs a little warm in these East Texas summers. A 6.2 is a diesel and comes with the largest factory radiator available. Why would you want to do away with that?? No matter how much air they move, electric fans won't move as much air as a fan & clutch arrangement. Get a fan, fan clutch and shroud to fit what you have and go with that.
Wallace6
Wyoming
Ray
Suburban
Well apparently the diesel radiator is gone along with the swap I guess. Mine has the 19" core . 28 or so wide. Also I might as well address the alternator and belt. I currently have a 7445 belt that runs fan/wp to alt. I don't see that belt number often, any suggestions
Wallace6
Wyoming
Ray
Suburban
I ended up getting a factory style 716 radiator it just showed up today. If weather permits I will be installing it tomorrow. My factory fan is a little bent on a few blades where it hit the old radiator,i did fix it best I could.
Will this be a problem? Thanks
Wallace6
Wyoming
Ray
Suburban
Well I did the radiator, did my best to straighten all the fan blades,all new hoses and seems to only hit 170 ish if I push it. Thanks for all the help on this site.
pistol85
