87 r10 gas tank problem
Mr.Chevy
Kyler
r10
350 tbi
Hi, Guys
On my 87 r10 has the dual tanks and i got a question...on the right hand tank I can fill it up and run it for pry 25-30 miles and the its like somthin plugs up somthing and it will barly idle and will run terrblly rough and if i put it in drive itll promply stall and then itll start for bout 2 seconds then stall but if i switch to the left itll run like a champ. And if i give it bout 15-20 mins and the right tank will run for a while again......Any thoughts or answers?
Georgeb
Wisconsin
George
K10 Burb Z71
Hi, Guys
Is it TBI with pumps in the tanks?
Mr.Chevy
Kyler
r10
350 tbi
Yes
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Sounds like an overheating pump. Is it the original? I'd think a replacement might be in order.
Georgeb
Wisconsin
George
K10 Burb Z71
If you could check the fuel pressure it would help too.
Mr.Chevy
Kyler
r10
350 tbi
Ues it is original
And Thanks guys ill check it out....!
4WDKC
Southern Florida
Kacy
Hi, Guys
Sounds to me like the pump is going out, if it runs fine on the other tank then it limits the problems to the part of the system that isnt shared with the other tank, ie the pump, sending unit, lines to the switch or electrical connections.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Replace the pump and in tank screen sock filter. The pump rums about $40 and the sock filter is about $5. Empty as much fuel as possible from the tank before dropping it to gain access to the pump. Also a good idea to clean off the years of collected dirt and other debris from the top of the tank, before removing the pump locking rings. I just replaced both of my pumps and filters from my 87 r10. Its not too dificult of a task.
Mr.Chevy
Kyler
r10
350 tbi
Ok thanks allot for the info guys!
ruggedly
