87 barn doors
Wallace6
Wyoming
Ray
Suburban
How do you tighten up the rear barn doors, I see a latch in the bottom of the door and a catch on the bottom sill.
Should I try sliding the catch towards the body a little?
Thanks
Wallace6
Wyoming
Ray
Suburban
Ok so I moved all the latches in and seals are in decent shape,where do I go from here?
Thanks
Are you dealing with leaks? Or just rattles?
Wallace6
Wyoming
Ray
Suburban
Rattle like crazy,I don't see a seal on the bottom of the sill, it honestly just doesn't close right and I have moved all the latches and nothing,any suggestions?
Thanks
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
There's a rod that goes to the top of the door it can rattle like a sun of a gun too. I think there's suppose to be a piece of foam donut to keep it from rattles. I used some pool noodle on mine. Helped alot.
Yeah, missing weatherstripping and improperly adjusted latches can cause a lot of rattles. If the rear sill is rotted out underneath, it can cause a lot of door rattles too, due to body flex.
Wallace6
Wyoming
Ray
Suburban
I just remembered too that Is it getting two clicks or just one? I had mine adjusted too far in and was only latching on first catch.
It certainly feels like one click, which part should I move? No rust on the vehicle
Originalthor
Scott
Suburban
There should be two clicks. Like the side doors. Try the latch at its furthest out position and see of you can feel the two clicks while closing slowly.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
The striker loops get worn and then the door adjustment will be off. Also the holes on these are slotted so there is some adjustment available.
Had this happen on my '90 Burb and several G series work vans. These striker loops used to be available at the dealership parts department, and they weren't very expensive (under $5 each IIRC).
tater dog
tater
k30
wrestled with mine for nearly 4 hours after installing new weather-stripping . i made the mistake of loosening the hinges and shimming the hinge plates . butchered up the
weather-strip before buying new ones and using baby powder to make them fit better .
88SQDRW
