80's interior bits
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
All off an 84 burb. Make an offer, and pay for shipping. I don't have Venmo or any money transferring apps like that.
-decent steering wheel. I believe I have the horn cap laying around somewhere, I don't think that's in great shape but not bad. May have one available from an 85 as well.
-a/c duct, the one that runs from the box, under the steering column then to the drivers side lower vent. In decent condition, the one connection point has a small piece missing. May have one for an 85 as well.
-a/c drivers side lower left vent, in good shape all around, the felt is a little weak but not gone. May have one for an 85 as well.
ON HOLD-rear factory spoiler, the truck also had a roof rack if that makes it different or not. It's in ok shape, some chrome bubbling, and the vinyl material is swelling around the mounting holes a little. No dings or anything like that, that I noticed.
PrairieDrifter
North Dakota
Mason
Pics
PrairieDrifter
North Dakota
Mason
Pics
PrairieDrifter
North Dakota
Mason
Pics
PrairieDrifter
North Dakota
Mason
Some more stuff
am/fm radio- in decent shape, I believe it worked fine, the push buttons are a little gummy, not sure how good it is. The outside case has some surface rust on the top, probably because the truck had a hole in the windshield. I have all four pieces for the knobs somewhere.
vacuum cruise control rod to the carb
Manual choke coil spring guy and linage rod
PrairieDrifter
North Dakota
Mason
@bucket
So I got to measuring, they are a little bit off compared to each other. So i decided to take one off to compare and it's about a 1/4 inch or so difference between the two mounts, acceptable.
So I noticed that one bracket didn't have one hole drilled all the way through and I didn't think much of it. But then I go to mount it back on and my brain started hurting, I was like why the hell is this thing so close to the edge, then I noticed that the hole punched out on the one bracket didn't match the spot on the other one.
It looked fine on the truck, but I don't think I would want to put this on a nice truck this way. Its one of those no one else would notice but it would eat at my ocd brain knowing it's there things lol.
Just let me know what you want to do.
PrairieDrifter
North Dakota
Mason
@just_some_guy
This is all that's left of this column in the 85, apparently the steering column was trash when the previous owner bought it so he replaced it with an even worse one that was sitting outside or in a shed lol... at least that's what it seems like. If not then the original column is just junk.
I think you can order those little plastic pin pieces. Let me know.
just_some_guy
Barclay
K5 Blazer Siverado
5.7L
@just_some_guy
Yes, perfect! I have the piece on the left but a spare lying around wouldn't hurt. The piece on the right I also have but it is busted into 2 or 3 pieces. I'd like to have em' all just PM me your payment info and I'll get settled up with you ASAP. Thanks again!
@bucket
Interesting! I wonder why they are different though?
Looks plenty good enough for me though! It should be no big deal at all to drill and tap new holes into the mounts so they match.
PrairieDrifter
North Dakota
Mason
The mounting bolts on the black side of the spoiler seem to be even but they are definitely not on the mounts. Maybe the mounts came as blanks and they had to drill and tap if someone wanted to add it on? Maybe because of the difference of the bend it had to be mounted like that? I don't know lol
I also couldn't find the middle mount, but I swear I have it, it's just somewhere stupid. If I find it'll I send it to you, no worries on that. I'll be able to get to some spring cleaning once it warms up here and I'll be able to check all my spots.
Sounds good! Just pm me what you'd want to do!
PrairieDrifter
North Dakota
Mason
Pm'd you tracking number, in case you didn't have alerts on.
PrairieDrifter
North Dakota
Mason
Steering wheel in picture is sold.
Will get a picture of the other one.
Spoiler is sold.
PrairieDrifter
North Dakota
Mason
@oldretiredafguy
Just making sure you know I pm'd you! I know some don't have notifications on.
PrairieDrifter
North Dakota
Mason
Radio and cruise control rod are sold.
Have the one steering wheel with no center cap or horn parts, I still need to get a pic up.
Still have the a/c vent stuff and the choke coil guy.
PrairieDrifter
North Dakota
Mason
Stuff not sold
-choke mechanism, also found its little cover.
-a/c duct and vent
aultinator
