8 MPG?
MisterB
Northwest
AJ
GMC K2500 4X4
I know we don't drive these trucks because they get good mileage. Just trying to make sure I have mine dialed in and I'm getting all I can.
1980 GMC K2500 3/4 ton, 35" mud tires, 6" lift, crate 350 motor recently refreshed with new plugs/wires/cap/rotor/K&N/all new synthetic fluids everywhere. Carb has been cleaned, and gas additives run through system. Cooling system flushed, new fluid, hoses, thermostat, and gasket. All new vacuum hoses.
This last tank of gas I didn't do any highway miles (rarely ever do anyway). It was all city, and I got 8 MPG.
Is that about what I should expect with how I have this rig set up?
Sent from my SM-N975U1 using Tapatalk
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Gear ratio?
And it's a th400 trans right?
Sent from my SM-G965U using Tapatalk
Green79Scottsdale
G.R. - MI
Bob
IMO, yes, that's what you should expect. I have a '79 K20 with stock 400/400/3.73/31" tire combo and get a consistent 10mpg. These are already aero challenged, and a lift and bigger tires doesn't help.
Love the velcro puppy!
MikeB
North Texas
Dual exhaust thru low restriction mufflers? Heat riser valve working properly? If using a cat converter, is it fairly new?
Are mechanical and vacuum advance working properly? A total of approx 45 degrees at low-load cruising speeds will help economy. That's initial + mechanical + vacuum.
Dmack
Central OR
Dave
Sounds about right. Mine is similar - factory crate 350, 4 speed, 4.11 gears, 4" lift, 35's. I get 10 with mostly in town driving.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Efi and computer controlled timing got me up to 14ish with mostly 50mph rural roads and almost no stops. I only have 33s though. 4l80 should get me a couple more.
8 seems a bit low, but in the ballpark. Maybe get a WBO2 sensor and dial in your carb that way. You could probably get 10-11 with a conservative driving style and a perfectly tuned carb.
MisterB
Northwest
AJ
GMC K2500 4X4
Gear ratio?
Th400. Not sure about gear ratio
MisterB
Northwest
AJ
GMC K2500 4X4
Headers through single Flowmaster.
Not sure about your other questions
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
A warmed up 350 with 4 barrel in a 2wd can get 20 mpg... I've done it.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Never get this with a low compression engine.
dvdswan
Port Orchard, WA
Dave
Vacuum gage can help with better mpgs.
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
I get about 11mpg. V20 Suburban, 37's, 4.10 gears, TH400. That's a TBI, but with no 02, so runs a tad rich.
MisterB
Northwest
AJ
GMC K2500 4X4
Are you talking about a gauge like this? This is the best I could get it adjusted a few weeks ago when I did it
mikejeden
