'77 K20 350 Engine Starter wire heat shield
pleary36
Boston
Pat
Reinstalling the motor and having trouble figuring out how to install the heat shield for the starter wires. Can anyone assist?
There was a couple different styles, but normally they mount with the bellhousing bolts. There's a thread around here with pictures, I'll see if I can find it.
pleary36
Boston
Pat
Thank you
I just found the picture from Hot Foot 4/25/20. I went out it lined right uo and bolted right in. the top bracket bolted on the bellhousing with the trany dip stick and the bottom slid over the back of the bolt holding the solinoid on the starter.
Thanks Again,
pleary36
PapaBear8486
