rwhite1
- Jan 25, 2014
- Lakeside
- Richard
- K10
I have a 77 chevy k10. Replaced the dual tanks with new sending units. I took the fuel tank wiring harness out of another 77 chevy truck I have. The Fuel Gauge is pegged past full and I cannot figure out why it wont work or go down and read properly?
The sending units are new and properly grounded to the frame. The fuel tank selector valve operates correctly from the selector switch on the dash. (it is the solenoid type selector switch) I replaced the fuel tank wiring from another 77 chevy truck I have in to this one. The wire that runs down the passenger side of the frame rail is also hooked up correctly (I think) the plug is tough to see if it plugged in right. But the selector valve works just fine. I have pulled the instrument cluster down to check the connections on the back of the fuel gauge and everything seems to work fine. Although I can move the gauge towards empty w ignition off w my hand, and when I turn the key on it pegs way past full. I have also checked the sending units (they are new) with the multimeter and have been getting 8.2 ohms out of the sending units with the tank near empty. I have also checked the wiring plug that runs off the firewall for the fuel tanks and it appears to be just fine as well.
I can't figure out why the gauge keeps peging out past full.. Any ideas or suggestions?
Thanks,
Richard
1977 K10 Chevy shortbed w/ 350
Thanks,
Richard
